Let the fun begin..............
PostPosted: Wed Dec 14, 2011 4:56 pm    Post subject: Let the fun begin.............. Reply with quote
Well, after a year of collecting, mostly the past 3 months, its time.........
[/img]
PostPosted: Wed Dec 14, 2011 5:55 pm    Post subject: Reply with quote
Miller time?
Hammer time?
Paradoxical time?
Man of the year Time?
PostPosted: Thu Dec 15, 2011 7:57 am    Post subject: Reply with quote
time for a new bump stick and some goodies to go with it.
After this, I will basically have a zz4 with tpi injection. Very Happy
PostPosted: Thu Dec 15, 2011 7:09 pm    Post subject: Reply with quote
izcain
9sec Club
PostPosted: Fri Dec 16, 2011 8:54 am    Post subject: Reply with quote
It's always fun to get that timing cover to seal back up without taking the pan off! Smile
9.17 @ 148
IROCDave
PostPosted: Fri Dec 16, 2011 4:33 pm    Post subject: Reply with quote
Floor jack, bottle jack, busted knuckles, BFH, bent coolant lines, lots of swearring and yet it will still leak oil when done. Lots o fun.
PostPosted: Fri Dec 16, 2011 5:22 pm    Post subject: Reply with quote
Laughing
PostPosted: Fri Dec 16, 2011 6:08 pm    Post subject: Reply with quote
Yea, started jacking the car up tonight.
No coolant lines to bend Very Happy
PostPosted: Sat Dec 17, 2011 11:25 am    Post subject: Reply with quote
Slowly getting there. Did end up taking the pan off.
:edit: oil pan back on, back on motor mounts, WP and pully on, radator back on, fans on, rocker studs tightened, rockers on. Intake welded, ground, and cleaned.
Crank pully ended up coming back off Rolling Eyes
Still need to put exhaust and starter back on.
PostPosted: Mon Dec 19, 2011 11:42 am    Post subject: Reply with quote
Getting exciting! Very Happy
PostPosted: Mon Dec 19, 2011 8:00 pm    Post subject: Reply with quote
On hold here tell Wed night.
BTW, can people see my pics since there from FB and nobody could see my video?
PostPosted: Mon Dec 19, 2011 8:07 pm    Post subject: Reply with quote
Pictures show up for me.
PostPosted: Mon Dec 19, 2011 8:22 pm    Post subject: Reply with quote
And me.
izcain
9sec Club
PostPosted: Mon Dec 19, 2011 9:21 pm    Post subject: Reply with quote
same here pics look fine!
9.17 @ 148
PostPosted: Wed Dec 21, 2011 3:31 pm    Post subject: Reply with quote
Got it together, go to start it for the first time get some loud clacking and no fire. Second try, no noise, but no start.
Crying or Very sad
PostPosted: Wed Dec 21, 2011 4:09 pm    Post subject: Reply with quote
Sounds like timing or Cam timing.
Did you degree the cam or just install it straight up? Did you turn the engine over 1 full rotation before installing the distributor?
PostPosted: Wed Dec 21, 2011 4:31 pm    Post subject: Reply with quote
The chain only had one notch, so no degreeing it.
Um, cant remember on dizzy. I'm starting to think maybe half way.
:edit: more I think, I stabbed the dizzy on #4. crap!
PostPosted: Wed Dec 21, 2011 4:57 pm    Post subject: Reply with quote
When you line up the timing gear marks to put the chain on, you are TDC of #1 exhaust stroke. So you need to rotate the motor 1 full turn lining the timing pointer up, then stab the dizzy on #1.
PostPosted: Wed Dec 21, 2011 5:36 pm    Post subject: Reply with quote
I took it apart with mark up, mark up, dizzy on 1.
But I had to rotate the motor to set the rockers, and I did that before I put the intake on and dizzy. Didnt rotate it back. UGH.
Still doesnt explain noises.
PostPosted: Wed Dec 21, 2011 5:58 pm    Post subject: Reply with quote
yIIKES.
Never put the chain on mark up mark up.
The marks are there to point at each other and make sure you didn't run it a tooth off.
Noises could be a number of things. Valve adjust, Timing, Lifters that haven't seen oil yet.
