Posted: Fri Dec 09, 2011 10:28 pm Post subject: |
Twilightoptics wrote: | Variable resistor fuel pump relays have been out since the 80's. They are unreliable, and the slightest bit of corrosion or bad connection and suddenly you're lean.
Bad idea. |
Variable resistor relays aren't what I'm thinking of, that's not going to run higher than input voltage, is it? 14.5v in, 18v out? |
Posted: Fri Dec 09, 2011 10:41 pm Post subject: |
You already bought the stuff. Just run what you got and see how it works. Not sure what you did, but I had my Racetronix harness built ready to accept their voltage booster if I need it.
People are selling slightly used injectors on LS1tech all the time in the range of 60 - 80 lbs. |
Posted: Fri Dec 09, 2011 11:11 pm Post subject: |
Once you start getting into the higher lb'ers they get fewer and farther between. That's where I got these little guys. I'm keeping my eye out for larger all the time though. Cheap, of course. |
Posted: Sat Dec 10, 2011 6:29 am Post subject: |
I see it all the time. I'll keep my eyes peeled for you. Tall or short style? Mostly I see talls. |
Posted: Sat Dec 10, 2011 10:11 am Post subject: |
title was a little misleading. thought it was a different green that youvwould say mmmm too. my bad. |
Posted: Sat Dec 10, 2011 12:07 pm Post subject: |
QwkTrip wrote: | I see it all the time. I'll keep my eyes peeled for you. Tall or short style? Mostly I see talls. |
Talls, I'm still rocking the LS6 intake. Thanks buddy! |
Posted: Sat Dec 10, 2011 12:19 pm Post subject: |
I found some 103# but I don't think you're that cool yet. |
Posted: Sat Dec 10, 2011 1:12 pm Post subject: |
QwkTrip wrote: | I found some 103# but I don't think you're that cool yet. |
There's an angry idle! _________________ A redline a day keeps the carbon away! |
Posted: Sat Dec 10, 2011 3:40 pm Post subject: |
At some point do they start using 2 sets of injectors? A smaller set for idle and up to a certain level then kick in a second set? |
Posted: Sat Dec 10, 2011 5:33 pm Post subject: |
Something else thats "boost referenced" remember your intake valve springs will be weaker by what ever psi you run X the area of the valve. |
Posted: Sat Dec 10, 2011 5:41 pm Post subject: |
chevymad wrote: | At some point do they start using 2 sets of injectors? A smaller set for idle and up to a certain level then kick in a second set? |
I'm not sure about other ECUs but MegaSquirt can control fueling down to microsecond increments so has no problem at all idling an engine with gigantic injectors. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sat Dec 10, 2011 5:48 pm Post subject: |
Alphius wrote: | chevymad wrote: | At some point do they start using 2 sets of injectors? A smaller set for idle and up to a certain level then kick in a second set? |
I'm not sure about other ECUs but MegaSquirt can control fueling down to microsecond increments so has no problem at all idling an engine with gigantic injectors. |
Unless the injector isnt that quick. |
Posted: Mon Dec 12, 2011 8:42 am Post subject: |
chevymad wrote: | Something else thats "boost referenced" remember your intake valve springs will be weaker by what ever psi you run X the area of the valve. |
Guess it should also be mentioned that the effective fuel rail pressure also decreases the same amount without a rising rate regulator. I still dont see why you need #60 injectors. |
Posted: Thu Dec 15, 2011 12:20 pm Post subject: |
Next piece of the puzzle... It's fricken 4" thick! |
Posted: Thu Dec 15, 2011 12:39 pm Post subject: |
Can you say ice machine? _________________ A redline a day keeps the carbon away! |
Posted: Thu Dec 15, 2011 11:13 pm Post subject: |
Hopefully I don't lose too much efficiency with it being so thick but I know for sure it'll fit between the frame rails! |
Posted: Wed Dec 28, 2011 8:39 pm Post subject: |
So...I bought these 60s... And I got that wastegate from Zac.
Need a BOV and some tubing and that's it. With these 60s I think I'll be maxing out the next weak link. Turbo? Headgasket? rods? Who knows! I guess I should start shopping for a replacement motor to swap in case something goes down. Obviously I'll be upp'ing the displacement if that happens. 6.0 here I come. |
Posted: Wed Dec 28, 2011 8:42 pm Post subject: |
Those Siemens Deka's? |
Posted: Wed Dec 28, 2011 8:48 pm Post subject: |
