Leejo2005 Member
Posted: Mon Oct 31, 2011 5:03 pm Post subject: tranny prime |
Does an automatic transaxle require the pump to be primed?
I just got my Taurus back together after rebuilding the transmission and it doesn't move in any gear. I'm hoping that the pump isn't sucking fluid up yet. |
jchaussee Member
Posted: Mon Oct 31, 2011 7:43 pm Post subject: |
| I dont know about a taruas, but when i did my truck, i didnt put in enough fluid so i didnt go into gear. Ended up being 12 quarts if i remember correctly. |
Posted: Mon Oct 31, 2011 7:52 pm Post subject: |
| Converter filled? |
All oil working pumps need some fluid in them before start up to seal the sides, otherwise they just freeball. _________________ A redline a day keeps the carbon away! |
Leejo2005 Member
Posted: Mon Oct 31, 2011 8:34 pm Post subject: |
I have 13 quarts in it right now, I don't have the tools to check line pressure but I suppose I could loosen a cooler line and see if anything comes out with the engine off. They were bone dry when I put it together.
I have no idea how to prime the thing if it does need it. |
Posted: Mon Oct 31, 2011 8:39 pm Post subject: |
I'd try suction on each cooler line somehow.
Also, rev it up a bit. Alot of pumps don't get moving until off idle. _________________ A redline a day keeps the carbon away! |
Leejo2005 Member
Posted: Mon Oct 31, 2011 8:57 pm Post subject: |
| I guess I can try using the vacuum pump on one of the lines or something. Do you think I could push fluid into the valvebody/pump assembly through one of the cooler lines? |
