tranny prime
Leejo2005
PostPosted: Mon Oct 31, 2011 5:03 pm    Post subject: tranny prime Reply with quote
Does an automatic transaxle require the pump to be primed?
I just got my Taurus back together after rebuilding the transmission and it doesn't move in any gear. I'm hoping that the pump isn't sucking fluid up yet.
jchaussee
PostPosted: Mon Oct 31, 2011 7:43 pm    Post subject: Reply with quote
I dont know about a taruas, but when i did my truck, i didnt put in enough fluid so i didnt go into gear. Ended up being 12 quarts if i remember correctly.
PostPosted: Mon Oct 31, 2011 7:52 pm    Post subject: Reply with quote
Converter filled?
All oil working pumps need some fluid in them before start up to seal the sides, otherwise they just freeball.
Leejo2005
PostPosted: Mon Oct 31, 2011 8:34 pm    Post subject: Reply with quote
I have 13 quarts in it right now, I don't have the tools to check line pressure but I suppose I could loosen a cooler line and see if anything comes out with the engine off. They were bone dry when I put it together.
I have no idea how to prime the thing if it does need it.
PostPosted: Mon Oct 31, 2011 8:39 pm    Post subject: Reply with quote
I'd try suction on each cooler line somehow.
Also, rev it up a bit. Alot of pumps don't get moving until off idle.
Leejo2005
PostPosted: Mon Oct 31, 2011 8:57 pm    Post subject: Reply with quote
I guess I can try using the vacuum pump on one of the lines or something. Do you think I could push fluid into the valvebody/pump assembly through one of the cooler lines?
