		| Author | Message |
		| jchaussee Member
				|  Posted: Tue Oct 25, 2011 2:03 pm    Post subject: Decent deal?? |   |
				| Looking at an 87 iroc by my house. Hardtop, t5, posi all.stock except gor wheels. All parts there. Body in good shape. But has a bottom end knock . Has all interior. Guy wants 700. I really just want it for tranny, posi amd fog lights. If I sell tpi, wiring, my 700r4, snd rest of car, do you think I would break even?? |  |
		| Back to top |  |
		| Alphius Peanut
 1984  Chevrolet  Camaro Z/28
				|  Posted: Tue Oct 25, 2011 2:47 pm    Post subject: |   |
				| I think it's possible that you could break even on that. Especially if it was running and driving when you were done, but that might be a bit far-fetched if you're doing two transmission swaps.
 Keep in mind the flywheel from that car will not bolt up to your engine and the flexplate from yours will not bolt up to that car. So you would need a flywheel to do the 5-speed swap in addition to any other parts you were thinking of.
		| Back to top |  |
		| jchaussee Member
				|  Posted: Tue Oct 25, 2011 3:10 pm    Post subject: |   |
				| Thanks. I will have to read up on the swap, so I can figure out all costs. I offrtrd guy 500 so I will see what he says. I figure I can get a couple hundrwd foe my old tranny, couple more for tpi setup, then try and sell othet small parts. Should be close then |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Wed Oct 26, 2011 6:43 am    Post subject: |   |
				| Scrap shell is maybe $100-$150 depending on how much you leave in it. Core 700 is nearly worthless, running 700 maybe a $100 at most. TPI might be $100 but it's impossible to sell a TPI as a set, you have to part it. How's the dashpad? Ground effects complete and in good shape?
 I think you will not break even, but I think that at the end of the day you will end up not losing more than a good axle and T5 would have cost you anyhow, so I support the endeavor.
		| Back to top |  |
				|  Posted: Wed Oct 26, 2011 7:26 am    Post subject: |   |
				| I've gotten close to 400 out of 3 different TPI setups. eBay is the way. They aren't worth anything to thirdgen guys. _________________
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 1:39 pm    Post subject: |   |
				| Ya. I couldn't get him down to 500. He was pretty firm at.700. One thing I have noticed , its that parts prices do tend to go up in the winter. Amd to follow up with.what paul said, I have seen tpi systems on cl for around 300 to 400, but I don't know of they are selling for that much. The rest of car is clean except one of the lower back seats aretorn and it has a red interior, which isn't that desirable. |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Wed Oct 26, 2011 3:01 pm    Post subject: |   |
				| If it's that clean why not put another motor in it, swap the transmission,s and sell it as a runner? |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 3:12 pm    Post subject: |   |
				| I dont have another motor lying around , plus its white with a red interior, and a hardtop. Don't know alot of people looking for that particular combo.though the thought did cross my mind . |  |
		| Back to top |  |
		| aaron_sK Member
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 3:20 pm    Post subject: |   |
				| Yeah I did. I took a pic of the rpos and then looked them up. |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Wed Oct 26, 2011 3:23 pm    Post subject: |   |
				| People seem to be all about that stuff. Boggles my mind, honestly. I can swap spings, sway bars and wheels in a few hours and make me an "IROC".
 But whatever.
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 3:27 pm    Post subject: |   |
				| I just looked at that motor. Will the 87 intake bokt to the 86 heads? |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 3:29 pm    Post subject: |   |
				| And as far as iroc. A person like you or myself coukd care less, because.we would be changing stuff.anywyas, buy some people like,to keep them as close to stock as they xan. |  |
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Wed Oct 26, 2011 3:47 pm    Post subject: |   |
				| If that was around here or I had a way to bring it up here I would probably buy it if it's that clean. The red interior is kinda lame though. _________________
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 4:07 pm    Post subject: |   |
				| Its clean as far as parts go. Has all itsvemblems, chin spoiler not cracked , didnt feel likepinch welds were.messed up, had all of its interior, but it also probably wasnt maintained as.far.as suspension, because the shocks sucked, prob original, and door sgged real bad. Also one thing it was missing was elect fan and the snorkle for tpi. No magor dents that I saw, and I didnt drive it yet to check tranny or posi. |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Wed Oct 26, 2011 4:11 pm    Post subject: |   |
				| If it's missing the snorkel for the intake then it's probably missing the MAF sensor too, huh?
 If you do test drive it keep the speed up. No fan no bueno.
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 4:17 pm    Post subject: |   |
				| Has mech fan. I didn't look for MAF, because I am not smart enough, but I guess it has snorkal to where it goes into the plasic piece that splits into two. So I guess I can say it has partial snorkle, just missing the plastic piece. I may check it out tommorow. Take it for a spin, point out everthing wrong with it and try to get it for 550 600 bucks |  |
		| Back to top |  |
				|  Posted: Wed Oct 26, 2011 4:24 pm    Post subject: |   |
				| To make an '87 intake fit '86 heads you have to machine the center 4 bolt holes. _________________
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Wed Oct 26, 2011 4:49 pm    Post subject: |   |
				| What exactly is wrong with the motor?
 I bought a TPI Trans Am for $500 once because it had "a spun rod bearing" according to the guy selling; when I want to look at it, the clanking was a bad waterpump bearing. I bought it right then and there.
 That car is still running and driving today, with a new waterpump on it.
		| Back to top |  |
		| jchaussee Member
				|  Posted: Wed Oct 26, 2011 5:07 pm    Post subject: |   |
				| I haven't drivin it yet, so I dont lnow. But he says one of his kids put the mech fan on backwards , which caused car to I've heat, which spun a rod. |  |
		| Back to top |  |
