anybody have a factory service manual for 89??
BluFbdy
PostPosted: Fri Oct 14, 2011 12:48 pm    Post subject: anybody have a factory service manual for 89?? Reply with quote
Trying to get the c207 for 89 labeled with wire functions, 92 side is done but I used a FSM for it, tried sifting thru the diagrams on ATGO with little to no luck because the factory on shows which wire is actually a part of the c207, good news is I have one wire done! Which is vats....that I don't have anymore so its kinda like a losing win lol I also found out the 89's cooling fan wire goes thru the c207, but the 92 style goes thru the bulkhead by the brake booster..... so this is gonna be a fun little nightmare....
Bowtie is working on the motor right now, probly a week or two and 800 later its getting bored .30over, hot tanked, cleaned up, painted, and assembled with new pistons that aren't garbage and an 8 in balancer all I need to do is put on the heads and intake then project nightmare has a green light I wanna figure out a basic idea on my wiring first though so if anyone's got FSM's that would work I would definitely appreciate it!!!
jchaussee
PostPosted: Fri Oct 14, 2011 12:59 pm    Post subject: Reply with quote
i ahve an 86 manual. if they are same or close you more then welcome to use it.
PostPosted: Fri Oct 14, 2011 2:30 pm    Post subject: Reply with quote
Is this what you need? It's in the LSx conversion forum.
http://www.thirdgen.org/techboard/ltx-lsx/548647-additional-swap-information.html
BluFbdy
PostPosted: Fri Oct 14, 2011 2:34 pm    Post subject: Reply with quote
You sir are a GENIUS! I did the 92 by hand but that makes it easier! Time to compare and draw the lines
PostPosted: Fri Oct 14, 2011 2:49 pm    Post subject: Reply with quote
Nobody make any comment. Just let me bask in this moment.
PostPosted: Fri Oct 14, 2011 5:52 pm    Post subject: Reply with quote
Number 1.
PostPosted: Fri Oct 14, 2011 6:36 pm    Post subject: Reply with quote
I'm still trying to wrap my head around the idea that there was a useful post made on TGO... Shocked
BluFbdy
PostPosted: Fri Oct 14, 2011 8:35 pm    Post subject: Reply with quote
Haha no kidding right?! I've learned to use TGO for product info, there's still some old school guys on there that actually know wtf they're talking about and I usually to straight to them, pocket being the wiring guru lol
PostPosted: Sat Oct 15, 2011 6:23 am    Post subject: Reply with quote
If you know how to search and who to listen too there is a wealth of info on TGO. At least there was a couple years ago.
