kutison Member
Posted: Tue Oct 11, 2011 10:35 pm Post subject: Heater fuse. |
So my heater fuse randomly blew last spring and I never bothered replacing it. Every time I swap in a new one, the heater works until I turn the heat down. I have a 25 gauge fuse in there, this is correct gauge right?
And if that is the correct gauge, I just go hunting for a wire grounding out? |
BluFbdy Member
Posted: Fri Oct 14, 2011 12:51 pm Post subject: |
Gauge fuse? You mean amperage right? I beleiev 25 should do but if your blower motor is shorting the fuse then you need to break out a meter and get to probing for a short _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Oct 14, 2011 1:25 pm Post subject: |
Just a guess, since it goes when you turn the blower down. I would look at either the blower speed switch or the low speed resistor pack. _________________ 92 Camaro
Posted: Fri Oct 14, 2011 3:10 pm Post subject: |
| Resistor. |
BluFbdy Member
Posted: Fri Oct 14, 2011 5:34 pm Post subject: |
| Quasi-Traction wrote: | | Resistor. |
+1 if you had the leads touch itd cause an instant short, or go all or nothing on the blower as a band aid lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Oct 14, 2011 6:40 pm Post subject: |
| I'm betting switch. Resistor coils are air-cooled in the HVAC box, switches overheat sitting on top of the stereo. |
kutison Member
Posted: Fri Oct 14, 2011 9:11 pm Post subject: |
| Makes sense. |
