'85 Camaro Z28 - Parting out!
Goto page 1, 2, 3  Next
PostPosted: Fri Oct 07, 2011 4:32 pm    Post subject: '85 Camaro Z28 - Parting out! Reply with quote
Alright guys, I've decided to part out my old Z28. I've already salvaged parts off of it and just need this stuff gone. Most of the parts are still on the car so if you want something, please be a little patient. Anyone is welcome to come a pull their own parts. I'm not interested in shipping anything at this time, however, I can pass stuff along to other crewbies or meet up somewhere near the Portland metropolitan area. All prices are OBO, and don't be shy about making an offer or trades.
GFX: $25 per piece ($100 all) Sold
Front bumper: $25
Rear bumper: $25
Rear GFX: $30
Hood: $100 Sold
Doors: $50 each loaded
Hatch: $100
LH fender: $25 pending
T-tops: $25 each
A/C delete box: $30
Rear end: $100
Torque arm: $25
Panhard bar:$ 20
A-arms: $20 each
Spindles: $20 each
Automatic shifter: $10
Automatic shifter plate: $20
Center console: $25
Dash: $50
Steering column: $20
Seats: $20 each
Front carpet: $20
Overhead console: $10
Rearview mirror: $5
Engine wiring connector/pigtail: $2 each
Front cross member: $20
Driveshaft: $10
36mm hallow front sway bar: $25
21mm rear sway bar: $20
LT1 engine/harness/ECU: $500
3" Harwood fiberglass pin on hood: $250
New unused Flowmaster 80 series muffler: $100
Stock TPI exhaust manifolds: $10
Stock TPI single cat y-pipe: $10
unknown catback exhaust: $20 SOLD
1 pair 2" wheel adapters: $100 pending
TPI rail & body fuel lines: SOLD
3 sets of stock springs :$20 set (4)
TPI intake base, runners, plenum: $200
Edelbrock TES shorty headers/Y-pipe: SOLD
TPI intake to airbox rubber boot: SOLD
RS style smoked tail lights: $20
Front turn signals; smoked: $10
Side markers: smoked: $10
Steering wheel: $10
Fuel tank: $40
gray front seat belts: $20
T-5 "petals": $10
Stock T-5 shifter with knob: $10
T-5 slave cylinder/line/reservoir: $10
T-5 master cylinder: $10
Flywheel: $40
Bellhousing/shift fork: $50
TPI throttle cable: sold
I'm leaving a whole lot of stuff off here, so if there's something you want and don't see it, just ask. I can send pictures upon request through email or text message. I'm willing to separate anything and everything.
PostPosted: Fri Oct 07, 2011 4:46 pm    Post subject: Reply with quote
jchaussee
PostPosted: Fri Oct 07, 2011 7:05 pm    Post subject: Reply with quote
can i get he brackets that hold the ground efx to body. should be some wierd disc thing action. also if you could get t top bar off and seals
PostPosted: Fri Oct 07, 2011 7:43 pm    Post subject: Reply with quote
Looking for a matched set of door and trunk locks. Do not need interior lock. Prefer black.
PostPosted: Fri Oct 07, 2011 7:54 pm    Post subject: Reply with quote
Brackets are being sold with the GFX which are spoken for already. The T-top bar is doable but all the t-top seals are junk.
PostPosted: Fri Oct 07, 2011 7:57 pm    Post subject: Reply with quote
I know for sure that the hatch lock and passenger lock are matching and in good condition but I wanna say that the drivers door is not matching and looks like someone tried breaking in one time, I'm going to double check on that though.
PostPosted: Fri Oct 07, 2011 8:01 pm    Post subject: Reply with quote
Same problem mine have. Laughing
PostPosted: Fri Oct 07, 2011 11:35 pm    Post subject: Reply with quote
I bought this when I got my '84. All my locks were munched.
http://www.hawksthirdgenparts.com/camarofirebird82-92doorsandhatchlockcylinderset.aspx
jchaussee
PostPosted: Sat Oct 08, 2011 8:28 am    Post subject: Reply with quote
you wouldnt mind taking a picture of the bracket would you? i have actually n.ever seen it or know what it lookks like and i must be a one year thing
PostPosted: Sat Oct 08, 2011 7:55 pm    Post subject: Reply with quote
I can do that, are you talking about front, side or rear?
jchaussee
PostPosted: Sat Oct 08, 2011 10:00 pm    Post subject: Reply with quote
it is where the rear rocker attaches on body. it has these disk things that slide onto lilltle nibs on the car. i have the discs but am curious as to waht attaches to the discs. some tyype of braket that i havent seen, and am assuming it is a 85 only thing[/u]
PostPosted: Sun Oct 09, 2011 9:12 am    Post subject: Reply with quote
Rolling Eyes Duh
PostPosted: Sun Oct 09, 2011 10:35 am    Post subject: Reply with quote
Is your hatch pull-down motor in good working order? Mine works sometimes, always releases but doesn't always motor up, then I can't shut the hatch.
PostPosted: Sun Oct 09, 2011 4:23 pm    Post subject: Reply with quote
It's actually a slammer with electric release.
P.S. I still have 2 sets of aluminum drums for you.
PostPosted: Sun Oct 09, 2011 8:58 pm    Post subject: Reply with quote
And the sad thing is that I had to replace my drums just before you picked them up for me. At least I can take them off and resell them as almost brand new. We need to set up a time to meet and get lunch or something Cool
PostPosted: Sun Nov 06, 2011 1:52 pm    Post subject: Reply with quote
would you work a deal on all the T-5 stuff ? and is that a disc rear or drum ?
PostPosted: Tue Nov 08, 2011 2:53 pm    Post subject: Reply with quote
Greg, I may actually be looking at letting go of my NWC T5. I need to find out if a trade deal falls through for a BW super T-10.
Wild_child
New Member
PostPosted: Wed Nov 09, 2011 4:28 pm    Post subject: Reply with quote
is the A/c delete box still for sale?
PostPosted: Sun Nov 13, 2011 1:12 pm    Post subject: Reply with quote
Sure can, the transmission may be already spoken for, however everything else associated is still available. The rear end is a drum brake, 3.23, Posi, 10 bolt. The brakes are nearly brand new on it too Very Happy
Sure is.
minijensen
PostPosted: Sun Nov 13, 2011 3:59 pm    Post subject: Reply with quote
how's the driver seat?
Page 1 of 3
