Clutch chatter & high RPM shifting problems
PostPosted: Sun Sep 11, 2011 4:03 pm    Post subject: Clutch chatter & high RPM shifting problems Reply with quote
So I just got a '91 Z28 with an LB9 and T5. The previous owner put a new clutch in approximately 400 miles ago however it has a lot of clutch chatter. It's about as violent as wheel hop shaking the whole car. It only happens when I'm slipping the clutch between around 800-1500 RPM's. What could cause this? A non resurfaced flywheel? Loose flywheel/pressure plate bolts?
Also I just noticed that this trans likes to grind going into only 4th gear when I'm shifting at high RPM's (4k+) Otherwise it shifts perfectly into every gear under normal driving. I was thinking about doing a trans fluid flush and running synchromesh instead of ATF. Does anyone have any ideas what can cause this issue though?
PostPosted: Sun Sep 11, 2011 4:05 pm    Post subject: Reply with quote
Contamination, bad surfacing, bad clutch hub, motor mounts..
PostPosted: Sun Sep 11, 2011 5:44 pm    Post subject: Reply with quote
Grinding into 4th only is a bad synchro, or a mis-aligned bellhousing.
PostPosted: Sun Sep 11, 2011 6:40 pm    Post subject: Reply with quote
Also, if by some chance the dude put in a ceramic puck clutch, that could be a lot of the chatter. Could be bad clutch hub, poor flywheel surface, warped pressure plate.
The grind into 4th could hardly be anything else except synchro trouble.
PostPosted: Sun Sep 11, 2011 7:37 pm    Post subject: Reply with quote
Because it's high RPM, that leads me to think bell housing alignment. Does it do it when you're above 4000rpm, but at a steady state rpm?
I had a 6 puck unspring clutch once and it was grabby but didn't chatter. Could easily be they installed the clutch without turning the flywheel.
PostPosted: Wed Sep 21, 2011 11:13 am    Post subject: Reply with quote
While I had the car on the lift the other day I was taking a look at things and noticed that there is one bolt missing from the torque arm mount to the tailshaft. I wonder if that is causing enough play in the torque arm mount to vibrate like crazy? I'm also 99% this is a nothing-special stock replacement clutch. Another thing I noticed is that there is excessive bearing noise with the car is neural with the clutch out, push the clutch is and silence. Input shaft bearing?
PostPosted: Wed Sep 21, 2011 12:47 pm    Post subject: Reply with quote
I would guess TOB. Pressure on the fork pushes it and quiets the bearing.
Judging by the missing bolts, noise and clutch issues I would guess that there was a monkey or two in there trying to do a clutch job. I'd be pulling it back apart to find out what else they forked up.
Just my two cents.
PostPosted: Wed Sep 21, 2011 2:09 pm    Post subject: Reply with quote
Just my two cents.
Input bearings will shut up when you push in the clutch too. To verify if it's TOB, lightely press the clutch pedal in, don't disengage the clutch, but enough to push pressure on the TOB. If it's quiet it's TOB, if it's still noisey it's input bearings.
Some t5's are louder than others.
PostPosted: Wed Sep 21, 2011 5:40 pm    Post subject: Reply with quote
Paul is right, I have anecdotal evidence and logic:
I may have a bad input bearing, it growls on cold starts only when I park uphill but goes away when ATF gets tossed into it, the only way to shut it up is to get the clutch all the way to the floor, then you can hear it die off as the tranny stops spinning. A TOB noise should go away with moderate clutch pressure, but not necessarily all the way down.
PostPosted: Thu Sep 22, 2011 10:41 am    Post subject: Reply with quote
From what you guys have been saying I've determined that it's my input shaft bearing. Noise only goes away when clutch is fully disengaged. I'll be putting my car on the lift again today to add that missing tourque arm mount bolt.
PostPosted: Thu Sep 22, 2011 12:17 pm    Post subject: Reply with quote
Change the trans oil and drive it. Input bearings on t5's are weak. If you pull the trans out for any reason, change the bearings.
PostPosted: Thu Sep 22, 2011 10:21 pm    Post subject: Reply with quote
I'll be doing a trans fluid flush next week and using Synchromesh. I believe there is ATF in it right now judging by the sticker on the trans.
And BTW, I added that missing torque arm mounting bolt... Eliminated over half of the clutch chatter. Hardly noticeable anymore. But it's still kind of bad in reverse. but at least I'm not as worried about it breaking something anymore.
PostPosted: Thu Sep 22, 2011 11:05 pm    Post subject: Reply with quote
T5s just make odd noises sometimes. It's the nature of the beast. Wink
I have a NWC T5. Unknown mileage. My input bearing has been noisy for thousands of miles. Input shaft splines are twisted where the clutch sits. Case is not straight. About 5 bolts on the tranny are heli-coiled. I beat the crap out of it (clutch drops and powershifts) and it comes back asking for more. Shifts smoooth too. Laughing Better than my Subaru and better than my dad's short-stick T56.
Run it 'til it dies. It might surprise you. I know mine has. I do have a spare sitting in my garage for the day it dies, however.
PostPosted: Fri Sep 23, 2011 8:01 am    Post subject: Reply with quote
Tested that out today. Held a steady 4500RPM in 3rd gear, no grind going into 4th. What gives?
PostPosted: Fri Sep 23, 2011 10:33 am    Post subject: Reply with quote
The cases in a T5 are kinda weak. So if you torque arm wasn't held stable it could have been putting a weird load on the mainshaft, and so when you go to shift into 4th which is direct drive, the mainshaft line wasn't straight so it would grind. Same thing happens when the bellhousing is mis-aligned.
That's why alot of people including myself and Rodney, relocate the torque arm to a beefier cross member, so it's not loading the trans weird. Especially with higher HP.
T5 is only rated at 250ft/lb, but I think that is easily increased when the torque arm isn't there. There is a reason they last behind higher HP Mustangs better.
PostPosted: Sat Sep 24, 2011 4:10 pm    Post subject: Reply with quote
^ this. check the input also, and see how bad its wobbling with the trans loose.
PostPosted: Sat Sep 24, 2011 4:16 pm    Post subject: Reply with quote
yeah, although I'm sure you know this, but its because they mount straight in, verses the 17.5 degree angle towards the driver in the F-body chassis. And, Tremec was contracted by Ford, therefore, the larger contractor wanted to crush the competition. :)
