Looking for a few things
Goto page Previous  1, 2
PostPosted: Wed Apr 11, 2012 2:25 pm    Post subject: Reply with quote
Lower shifter boot
- 5 speed shifter plate
I have both of these. My shifter plate has a a couple cracks by two of the torx bolts and I buffed off the shift pattern.I have a lower boot as well, has one quarter sized rip.
you can have the lower boot, but I was hoping to get a buck or two for the shifter plate.
PostPosted: Wed Apr 11, 2012 4:45 pm    Post subject: Reply with quote
Cool, wanna just bring the Shift boot to Dyno? I'll pass on the shifter plate though. I'm looking for one in perfect condition.
PostPosted: Wed Apr 11, 2012 6:25 pm    Post subject: Reply with quote
you bet!
Outlaw28
PostPosted: Thu May 24, 2012 7:27 pm    Post subject: Reply with quote
i have a set of used koni struts came on car when i bought it i put new suspension on almost immediately after i bought it. they are yellows...not to sure on how many miles left on them i been saving them was ganna rebuild them but i might part with them
PostPosted: Fri May 25, 2012 2:43 am    Post subject: Reply with quote
You have LCA brackets listed twice.
Whats up with G-body control arms? Is that a modification I dont know about, or another project?
PostPosted: Fri May 25, 2012 4:51 am    Post subject: Reply with quote
Well duh, you need two LCA brackets for them to work properly;)
Awhile ago I had read somewhere that G-body A-arms bolt up to an F-body yet are 1" or 2" longer. That would greatly reduce the scrub radius on our cars and also allow for more room to get more steering angle. However, I'm starting to see conflicting reports about the truthfulness to that.
PostPosted: Fri May 25, 2012 10:42 am    Post subject: Reply with quote
how would longer a-arms change the scub radius, if you are using f-body spinles, the king pin angle will change to cancles out the added track width to the hub.
PostPosted: Fri May 25, 2012 6:44 pm    Post subject: Reply with quote
I guess I would assume when you ask for them, you would want a pair.
So on the arms, is the conflicting reports that they are longer, or help on the scrub radius?
Makes me want to go to the junkyard with a tape now Smile
Page 2 of 2
