Looking for a few things
PostPosted: Mon Sep 05, 2011 6:13 pm    Post subject: Looking for a few things Reply with quote
- Lower shifter boot
- 5 speed shifter plate
- clutch "petal" pad sourced via parts car
- lightweight flywheel
- drop spindles
- raised strut mounts
- LCA relocation brackets
- Recaro LS seats sourced @ VWvortex
- strut tower brace
- headers and y-pipe sourced @ Dyno Don
- sub frame connectors
- any kind of big brake set up
- Koni or Bilstein struts/shocks rears have been sourced @ eBay
- 3" and 2.25" wheel adapters
- speed density TPI cold air intake
- 5 point roll bar
- 6 bolt steering wheel adapter (MOMO)
- 1 pair chrome 18x9.5 corvette y2k wheels
- stereo amplifier. (800rms)
- stereo head unit. (w/iPod hookup or bluetooth) sourced through friend
- torque arm relocation mount/crossmember
- mig or tig welder
- 4th gen washer fluid tank
- G-body A-arms
I'll have a few more things to add but this is it for now[/b]
PostPosted: Mon Sep 05, 2011 9:14 pm    Post subject: Reply with quote
Is a lower shift boot worth it's weight in gold yet? Laughing
I have a pristine one, but it's going in my car ASAP.
If you're desperate, go on lowes.com and search for this item number: "53196"
That's what I used temporarily 'til I found the lower boot I'm using. It fits almost perfectly.
PostPosted: Mon Sep 05, 2011 9:18 pm    Post subject: Reply with quote
PostPosted: Mon Sep 05, 2011 9:21 pm    Post subject: Reply with quote
Rolling Eyes
Man, how are these rare? I had a couple from the JY when I swapped the T-56. Put one in my IROC sold the other. Found a nice one when Gabe was out here (he bought it), and got another good one in the Bananer.
Also, I just sold a good set of pedals with good pads and a five-speed plate to Bruce on Saturday. So yay for bad timing. Laughing
PostPosted: Tue Sep 06, 2011 7:38 am    Post subject: Reply with quote
Because GM no longer makes them, 4thgen ones don't fit, they're rubber that's exposed to road grime and oil, and idiots break/tear/remove them when they mess with our cars.
I've been junkyard hopping for years and the ONLY one I've ever seen was the one I bought when we were out together. You must just be lucky, man. Smile
PostPosted: Tue Sep 06, 2011 5:18 pm    Post subject: Reply with quote
Wanna argue about it? Razz
Actually I have never put a fourth gen unit on a factory shifter hole, only a hole I cut, so the holes might not line up or whatever, but the boot worked fine.
PostPosted: Tue Sep 06, 2011 6:00 pm    Post subject: Reply with quote
Hands off on this one, but I hear the 4thgen ones don't even come close to fitting a factory thirdgen shifter hole.
I do believe they are both discontinued from GM anyway. Wink But the 4thgen should be way easier to find at the junkyard.
PostPosted: Tue Sep 06, 2011 7:00 pm    Post subject: Reply with quote
See, I didn't have a factory hole in my IROC. So I got a fourthgen T-56 unit (different boot for T-5 and T-56 fourthgen, and yes, they are marked) and went with it.
PostPosted: Tue Sep 06, 2011 7:01 pm    Post subject: Reply with quote
Indeed they are discontinued, I think I'll do a little research on the 4th gen boots.
kurfbird
PostPosted: Tue Sep 06, 2011 8:15 pm    Post subject: third gens boots Reply with quote
I have three of these 3rd gen
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Tue Sep 06, 2011 8:17 pm    Post subject: Reply with quote
I never liked how my 4thgen boot fit.
PostPosted: Sun Oct 09, 2011 10:10 pm    Post subject: Reply with quote
Updated the first post with a few things, mostly aftermarket stuff.
charlie6178
PostPosted: Mon Oct 10, 2011 6:13 am    Post subject: Reply with quote
I have a set of LS1 rear brakes, and an extra strut tower brace laying around!
1992 Camaro 1LE Z28
PostPosted: Mon Oct 10, 2011 12:52 pm    Post subject: Reply with quote
Mmm, idk about the LS1 rear brakes, I already have PBR rear brakes which are not far behind LS1's. I'm more interested in front brake set ups. But which STB do you have, any pictures of it?
izcain
9sec Club
PostPosted: Mon Nov 28, 2011 8:39 pm    Post subject: Reply with quote
Got a set of hedman full length 1 5/8's but you would have to fab a y pipe for them.
9.17 @ 148
PostPosted: Sat Dec 03, 2011 11:28 am    Post subject: Reply with quote
I guess I need to edit my post. I actually ordered a set of Dyno Don headers and Y-pipe, but thanks for the offer!
PostPosted: Fri Dec 30, 2011 11:52 pm    Post subject: Reply with quote
Added a few more things.
PostPosted: Thu Jan 19, 2012 8:49 pm    Post subject: Reply with quote
I really need some Koni's, and Recaro's before March.
PostPosted: Fri Jan 27, 2012 11:35 pm    Post subject: Reply with quote
I found some Recaro's locally. Koni's and raised, solid struts mount are the highest on my priority list.
PostPosted: Mon Apr 09, 2012 7:09 pm    Post subject: Reply with quote
Added G-body A-arms to the list.
