Leejo2005 Member
Posted: Wed Sep 07, 2011 4:53 pm Post subject: 9 Bolt posi carrier and gears |
I have a used posi carrier with 2.77 ring and pinion from the axle I built. I changed ratios and no longer need this carrier or gear set. I can press new bearings on the carrier and/or pinion gear for a couple bucks.
Make an offer and we can go from there. |
