turbo_jimi Member
Posted: Sun Jul 17, 2011 6:09 pm Post subject: Tumwater Pick a Part |
They have a posi 3.27 with rear disk 9-bolt on a white 86 TA down in Tumwater. And a 140 speedo guage cluster from the same TA...not sure of condition of either. The diff. cover was laying a couple of feet away under the car. Gears looked clean from what I could tell. I'm too lazy to pull it and resell, so it's up for grabs. I ended up just buying a couple of fender brackets off of the IROC. Oh yeah, there is a tpi unit down there with the throttle body still attached. _________________
