		IROCDave Member
		IROCDave Member
				 Posted: Fri Jul 08, 2011 7:57 pm    Post subject:  |
				I shaved the injector bodies down tonight with a 25K die grinder without issues. It will be running tomorrow. I wonder how it will react to the larger injectors and old Ed Wright tune?
Should I clear the ECM before it starts up? |
   1991  Pontiac  Trans Am
				 Posted: Fri Jul 08, 2011 8:40 pm    Post subject:  |
				This has been an interesting saga. I can't wait to see if this solves it.
I'd definitely reset the ecm so it can get a fresh learn. _________________
 	  | Quote: | 	 		  | Sometimes I actually think I'm slightly retarded in the mouth. |
		IROCDave Member
				 Posted: Sat Jul 09, 2011 5:23 pm    Post subject:  |
				It was a tight fit but I got the injectors in and started it up. It ran like crap. It was missing badley and running pig rich. I used a this http://www.instrumart.com/products/10108/raytek-minitemp-mt6-infrared-thermometer?ctype=2&gclid=COTjgP_M9akCFQY-bAodZCvWZg
temp gun and found that the headers on the passengers side were cold while the drivers side tubes were at about 500 F.
For some reason the upper plenum sits lower on the passenger side and the injector plugs barely clear. They were not plugged all the way in. I used a pair of 12" needle nose plyers and forced them onto the injector until I heard the click. I also bumped the fuel pressure back to 43PSI.
It runs some what better but barely idles, stumbles at throttle transition and generaly runs really rich. I need to reset the minimum idle, TPS and timing again.
Ian, can you give me a hand with this? It takes to people becuase the car wont idle. |
				 Posted: Sat Jul 09, 2011 11:02 pm    Post subject:  |
				 	  | IROCDave wrote: | 	 		  | Ian, can you give me a hand with this? It takes to people becuase the car wont idle. |
Man, everytime you've called me I've been at work.   Are you wrenching on it Sunday? I get off around 2 and have to grab some parts and then can run over there and have the rest of the day to help you. |
