Cascade Crew Message Forums
Hielor Member
Posted: Sat Jul 30, 2011 7:38 pm Post subject: Third brake light for 91 camaro |
So I went to replace the bulb in my third brake light, and while I was poking around in there I thought "oh, this silver plastic reflector piece can come out, i'll pull that out and clean it." Two seconds later, the thing had snapped clean in half. Whoops.
I don't need the entire unit, just the reflector piece, but I'll take the whole unit if you want to get rid of it.
The unit looks like this:
http://www.tacreationsusa.com/images/Lighting/3rdBrakeLight/3BL_9192.JPG
Alternately, if anyone happens to know of a boneyard near me (I'm in Redmond) that would be likely to have this kind of thing, that would be valuable information since I imagine this will happen again in the future.
Thanks!
-Brandon |
Posted: Sat Jul 30, 2011 8:11 pm Post subject: |
I have one, just the reflector. The pigtail isn't attached to it anymore so you'll have to attach your own.
I work up the 405 from you in Bothell, but I don't drive in except for Saturdays when overtime is offered. I will most likely be in next Saturday and work until noon or 1:00, I can detour your direction on the way home. _________________ 92 Camaro
