drum brake e-brake cables
91camaro_rs
PostPosted: Fri Jul 01, 2011 5:34 pm    Post subject: drum brake e-brake cables Reply with quote
the little metal stoppers on my cables got pulled to the end therfore my e-brake doesnt work so i need new cables, anyone got them?
kurfbird
PostPosted: Fri Jul 01, 2011 5:45 pm    Post subject: Drum e brake cables Reply with quote
I have a rear end with cables from a 1991 camaro
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
Leejo2005
PostPosted: Fri Jul 01, 2011 5:45 pm    Post subject: Reply with quote
I've got some I can pull off my '83 Z28 if you'd like
2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383
91camaro_rs
PostPosted: Fri Jul 01, 2011 6:01 pm    Post subject: Reply with quote
ok that would be awesome if i could get the pair from one of you guys, the little metal stopper slid all the way to the end of the cable so when i pull the brake it hardly does anything, i think i pulled it up way to hard one day
PostPosted: Fri Jul 01, 2011 8:57 pm    Post subject: Reply with quote
I know this isn't what you're looking for but I have everything you'd need to swap pbr discs onto your ten bolt minus brake hoses and ebrake cables. So... you'd still need cables....just from a disc car. Laughing cheap!
Actually...I think I have ebrake cables around here too... Laughing
91camaro_rs
PostPosted: Fri Jul 01, 2011 11:14 pm    Post subject: Reply with quote
So how much would you want for that setup?
