IROCDave Member
Posted: Sat Jun 18, 2011 12:02 am Post subject: |
| Ian.. bout time to upgrade your brakes right? |
Posted: Sat Jun 18, 2011 7:19 am Post subject: |
I don't think that would be an upgrade, well not for the front. Those front rotors are the same size as mine, the ones I bought from Ian when he upgraded his fronts. _________________ 92 Camaro
Posted: Sat Jun 18, 2011 7:48 am Post subject: |
Yep, that would be a downgrade for Ian. Those are the brakes I just put on my car, C5 Z06. 13" rotor 1.25" thickness dual piston floating PBR caliper _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Jun 20, 2011 4:51 pm Post subject: |
me likey....only even if I bought those, I'm still gonna be a few bills in for bigger wheels/tires.
the 2001 sucked up what I had saved up for my wheel/brake fund by the hydraulics going south on me....(rickafrigginfraggin..) |
Posted: Mon Jun 20, 2011 4:54 pm Post subject: |
| Is there any difference between the C5/Z06 brakes and the standard C5 brakes, other than the color of the caliper? |
Posted: Mon Jun 20, 2011 5:26 pm Post subject: |
| Dewey316 wrote: | | Is there any difference between the C5/Z06 brakes and the standard C5 brakes, other than the color of the caliper? |
No, there is absolutely no difference aside from the red powdercoating.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Jun 20, 2011 6:49 pm Post subject: |
Some say the Z06 stuff was pressure cast vs drip casting? I only ever remember hearing about this back when the z06 came out, never again. |
Posted: Mon Jun 20, 2011 10:33 pm Post subject: |
| iansane wrote: | | Dewey316 wrote: | | Is there any difference between the C5/Z06 brakes and the standard C5 brakes, other than the color of the caliper? |
With some quick internet research apparently all C5 calipers are pressure cast. Lots of people saying the only difference is the color.  _________________ 84 Camaro Z28 - LS1/T56
