Alumn Waterpumps
PostPosted: Mon May 23, 2011 4:06 pm    Post subject: Alumn Waterpumps Reply with quote
Since I need to replace my waterpump I am wanting to go to an Alumn one. I did some searching online and noticed GMPP made some. But they no longer make or have one Rolling Eyes
Anyone have experience with other brands of some?
PostPosted: Mon May 23, 2011 4:45 pm    Post subject: Reply with quote
Never seen a need. Used some Edelbrocks for customers that seem to be okay.
To me the extra $ isn't worth the like 5lbs weight when the car's already a pig.
PostPosted: Mon May 23, 2011 5:30 pm    Post subject: Reply with quote
Part of it is weight yes. But most of it is that anything steel thats on my car for about 2 months rust. My rotors wont even last over night without getting a spots.
Few other things.. as I'm having problems finding one.....
A stock 350 is not reverse flow correct?
Our cars use a long shaft correct?
To "underdrive" you do smaller crank, and larger accessorys?
PostPosted: Mon May 23, 2011 5:33 pm    Post subject: Reply with quote
Most serpentine belts spin backwards.. but are not reverse flow.. if the water pump pulley is on the smooth side of the belt it is reverse rotation.
PostPosted: Mon May 23, 2011 6:11 pm    Post subject: Reply with quote
So your saying the pump would be CCW??
PostPosted: Mon May 23, 2011 6:15 pm    Post subject: Reply with quote
If you have a serp belt, the water pump spins counter clockwise, yes. Reverse rotation. Not reverse flow.
PostPosted: Mon May 23, 2011 6:26 pm    Post subject: Reply with quote
Yes, I'm serp.
So from summit it looks like here are my options
Edelbrock 8881
emp/stewart 23123
then add bolts
ARP-430-3202
then if I wanna go crazy and get new pullys
March 6371, 112, and 6312??
PostPosted: Mon May 23, 2011 7:35 pm    Post subject: Reply with quote
The reason I didnt say all serp belts turn ccw is because the systems with vbelts like my 87 have a flat serpentine type belt for the alternator. However the water pump has a grooved pulley for it and turns the conventional direction.
PostPosted: Mon May 23, 2011 8:17 pm    Post subject: Reply with quote
Single serp belts all have reverse rotation. Multiple belts have std rotation. Guess I never really consider the early serp/v-belt style "serp setup."
PostPosted: Mon May 23, 2011 8:20 pm    Post subject: Reply with quote
In order to be serpentine it kinda has to loop back on itself. Those are really just multi-V belts.
PostPosted: Mon May 23, 2011 8:42 pm    Post subject: Reply with quote
As you both say its not "serpentine" however it is the same kind of belt, which most people call a serpentine belt. Not really sure why gm went halfass with that setup.
PostPosted: Mon May 23, 2011 9:01 pm    Post subject: Reply with quote
I always figured it was a way to avoid belts slipping or being thrown. Sort of like Ford running two redundant v-belts over the alt and wp on some of their engines.
PostPosted: Mon May 23, 2011 9:08 pm    Post subject: Reply with quote
The newer alternator probably required a belt with more traction, and gm was too cheap at the time to change the rest of the system is my bet. But still.. if you have to change half the system why not just do it all right from the first eh?
Another oddball would be my 74.. it is supposed to use a standard vbelt.. with a tensioner.. on the back side.. serpentine style LOL
PostPosted: Mon May 23, 2011 9:16 pm    Post subject: Reply with quote
The backside of a v-belt? Nice. Laughing
BMW had bolt-down v-belt tensioners, but they always went on the proper side.
PostPosted: Mon May 23, 2011 9:35 pm    Post subject: Reply with quote
totally random thought... the LT1's had aluminum water pumps from the factory... just felt like bragging Very Happy
PostPosted: Mon May 23, 2011 10:00 pm    Post subject: Reply with quote
Lt1s are truly reverse flow cooling too. Wink
PostPosted: Tue May 24, 2011 2:36 am    Post subject: Reply with quote
yes they are. And it wont work with my setup Mad
PostPosted: Tue May 24, 2011 5:44 pm    Post subject: Reply with quote
I have a no-name aluminum one I picked up a few years back, that's still sitting in a box, but I think its the standard rotation for V-belt.
