RK82 Member
![](images/avatars/12143026364ea72a732d52f.jpg)
1982 Pontiac Trans Am
Posted: Fri May 27, 2011 3:53 pm Post subject: vacuum reading |
does this vacuum reading seem weird, it kinda bounces around, I can't remember if it did that the last time I hooked up the gauge.
also does this seem like alot of water to come out the exhaust?
it was only idling for like 15-20 minutes, I drove it around before this, water temp was 185-190 |
Posted: Fri May 27, 2011 3:54 pm Post subject: |
Water in the exhaust is just condensation. Coolant in the exhaust is what you want to watch out for. If you're not sure, smell or taste it. |
RK82 Member
Posted: Fri May 27, 2011 4:08 pm Post subject: |
aaron_sK wrote: | Water in the exhaust is just condensation. Coolant in the exhaust is what you want to watch out for. If you're not sure, smell or taste it. |
it didn't smell like coolant, I am to afraid to taste it |
![](images/avatars/17565934854c4f4e4ab6f09.gif)
Posted: Fri May 27, 2011 4:14 pm Post subject: |
RK82 wrote: | aaron_sK wrote: | Water in the exhaust is just condensation. Coolant in the exhaust is what you want to watch out for. If you're not sure, smell or taste it. |
Don't be afraid. What don't kill ya will only make ya stronger, right?
Bouncing vacuum gauge at idle means a vacuum leak, a misfire, a valve event not happening correctly (overtightened valve lash keeping a valve open) or possibly low compression in a cylinder. Basically, it's just not firing with equal strength all the time. I've seen that happen from a very badly adjusted idle circuit on a carb as well, either far too rich or far too lean. _________________ 84 Camaro Z28 - LS1/T56
![](images/avatars/7553907974deab2f042818.jpg)
Posted: Sat May 28, 2011 2:22 am Post subject: |
weird.
I've been having weird intermittent idle problems in spite of new plugs/wires, and checked the oil, popped both valve covers and made sure I checked lash correctly. nothing seems amiss.
The strangest thing is, it will idle fine, but it has this weird dip in idle for a couple seconds, then, its back to normal. when I step out of the car, take the air element off, and plug the air bleeds on the pass side, it idles right, and there's never a dip, even after 3-4 minutes of doing that.
I sure hope I'm not dealing with the valvespring problem that Brandon has been fighting. my cam does have kind of a soft ramp rate so I'm rather doubtful it's that.
I'm choosing to blame the main body of my carb. Baseplate was warped and replaced before I ran it (after a good clean-up) so who knows what the hell happened before that. _________________
![](http://www.uzzisoft.com/randomsigscript/Quasitraction.jpeg) |
