Posted: Wed Apr 20, 2011 5:15 am Post subject: who was it here........ |
| That bought the kyb adjustible struts? Do you have them on yet and feedback to others who may get them. |
RK82 Member
Joined: 27 Jul 2008 Posts: 168 Location: vancouver B.C
1982 Pontiac Trans Am
Posted: Fri Apr 22, 2011 12:51 pm Post subject: Re: who was it here........ |
| 91RSVert wrote: | | That bought the kyb adjustible struts? Do you have them on yet and feedback to others who may get them. |
probably me, I put them in a few weeks ago haven't really driven the car that much, out of all the stuff I've done to my car shocks and struts have been the most noticeable upgrade but then again all I have to compare them to is a replacement set of Monroes.
the KYBs are 1000x better than monroes |
Posted: Fri Apr 22, 2011 5:18 pm Post subject: |
Thanks. Ive got kyb non-adjust now that are about 7 years old. I'm guessing its about time to replace as I can push them with my body weight(and I'm skinny).
How easy are they to adjust while on the car? |
RK82 Member
Posted: Fri Apr 22, 2011 8:59 pm Post subject: |
| 91RSVert wrote: | Thanks. Ive got kyb non-adjust now that are about 7 years old. I'm guessing its about time to replace as I can push them with my body weight(and I'm skinny).
the fronts are easy the knobs right on top of the strut, they even comes with two little flathead screw drivers to adjust them. the rears are kinda of a PIA you have to crawl under the car to adjust them. I've played with the adjustments a little, it doesn't feel like there's a whole lot of difference from the stiffest setting to the softest setting |
Posted: Sat Apr 23, 2011 4:28 am Post subject: |
oh, so the fronts are like konis? I thought they had a knob on the side of the body.
So the rears you just crawl under and turn a knob right? |
Posted: Sat Apr 23, 2011 9:33 am Post subject: |
I've got close to ten years on my std kyb. And they're fine. More about mileage vs terrain. _________________ A redline a day keeps the carbon away! |
RK82 Member
Posted: Sat Apr 23, 2011 9:38 am Post subject: |
| 91RSVert wrote: | oh, so the fronts are like konis? I thought they had a knob on the side of the body.
I just remembered I took pictures of the adjusters
front
rear
Posted: Sat Apr 23, 2011 10:36 am Post subject: |
| Twilightoptics wrote: | | I've got close to ten years on my std kyb. And they're fine. More about mileage vs terrain. |
Which is why you should never offroad your thirdgen with performance struts/shocks. _________________
Posted: Sat Apr 23, 2011 11:24 am Post subject: |
twilight. While your correct, I will say my x drove the first car they were on for a year and she lived on some shitty roads. Then I have had them 5-6 on this car. While it doesnt get drove alot, I push it to its limits.
But none the less, if I can push it in with little effort, IMO they are bad.
RK82, thanks for the pics. Gives me a good idea what I'm dealing with. Does look like the rears are hard to get to. But still easier then konis that you have to dismount to adjust. |
