MrMike98 Member
Posted: Thu Apr 07, 2011 4:30 pm Post subject: new spring "stance" |
how long does it take new springs to "sag" to there ride height??
and do u have to be driving or does just setting in the garage count??
how much will pro lines drop from install to settled in??
thanks
Mike |
Posted: Thu Apr 07, 2011 5:23 pm Post subject: Re: new spring "stance" |
how long does it take new springs to "sag" to there ride height??Can take weeks.
and do u have to be driving or does just setting in the garage count?? Way faster if you drive it.
how much will pro lines drop from install to settled in?? Depends on how sagged your original springs were. _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 07, 2011 5:42 pm Post subject: |
x2 on twilights response. I have had new springs in my 1ton for over a year and once n a while you can still here them "pop".
Make sure you got time indexed/installed properly. They wont sit into place if not rotated properly. _________________ 2008 GMC Z71
