Posted: Sat Apr 16, 2011 10:55 am Post subject: |
One digit. _________________ A redline a day keeps the carbon away! |
Posted: Mon Apr 18, 2011 8:21 pm Post subject: |
For some reason I thought 305's used a different head gasket than a 350 due to the smaller bore... But I guess that isn't the case? |
Posted: Mon Apr 18, 2011 8:56 pm Post subject: |
Hmm forgot about bore.
Hehe
Look for the equivalent in 305 sizing lol. _________________ A redline a day keeps the carbon away! |
Posted: Tue Apr 19, 2011 2:52 pm Post subject: |
Is it really? I thought they had some with smaller bore sizing to keep compression up a little bit? _________________ A redline a day keeps the carbon away! |
Posted: Mon Apr 25, 2011 5:42 pm Post subject: |
Just got the heads out the machine shop, having them shaved .030". The machinist was worried about a couple things.. One being that with over .500 lift Im getting close to needing screw-in studs? What do you guys think? _________________
'88 FORMULA |
Posted: Mon Apr 25, 2011 5:48 pm Post subject: |
fiveoformula wrote: | One being that with over .500 lift Im getting close to needing screw-in studs? What do you guys think? |
if you running higher spring pressures, this is an even bigger . |
Posted: Mon Apr 25, 2011 5:53 pm Post subject: |
...an even bigger what? lol |
Posted: Mon Apr 25, 2011 5:54 pm Post subject: |
An even bigger....YUP. |
Posted: Mon Apr 25, 2011 6:03 pm Post subject: |
Hmm ok, I'll see what he'll charge to put those in, you have them Dew? |
Posted: Mon Apr 25, 2011 6:47 pm Post subject: |
The them milled for screw in studs. The GOOD kind with a flange. Should run about $100.
If you use the stud remover tool and tap the boss for non flanged screw ins you run the risk of breaking the stud boss, and they aren't nearly as accurate. _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 28, 2011 6:11 pm Post subject: |
Alright, so Heads are at the machine shop getting the studs put in, they charged me $120 bucks plus $40 for the studs, so I think I did alright. The intake, TBI adapter, and springs got here, just waiting on the cam since it was a special order. Im stoked! |
Posted: Thu Apr 28, 2011 6:13 pm Post subject: |
Its too bad you have that stupid '88 only computer. I bet my current BIN would be a descent place to start at on your motor. |
Posted: Thu Apr 28, 2011 6:21 pm Post subject: |
Yeah that just makes it a pain... maybe I could copy a bunch of the values or something? Or I never researched an ECM swap maybe I could do that. |
Posted: Thu Apr 28, 2011 6:23 pm Post subject: |
it won't be too bad. You'll need to give it timing, and probably trim fuel at idle and down low, then add fuel in the upper tables. Once you get it running, just drive, and work on getting the BLM's close to 128, and WOT tuned to where you want it.
--John |
Posted: Thu Apr 28, 2011 6:25 pm Post subject: |
And make sure the camshaft dowel for the gear is tapped in far enough. Otherwise you'll wonder what that alien spaceship sound is until you pull the cam out in favor of the stock cam for DEQ purposes and find wear marks! _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 28, 2011 6:28 pm Post subject: |
Twilightoptics wrote: | And make sure the camshaft dowel for the gear is tapped in far enough. Otherwise you'll wonder what that alien spaceship sound is until you pull the cam out in favor of the stock cam for DEQ purposes and find wear marks! |
WORD!
(You probably don't need to ask why Paul and I know this) |
Posted: Thu Apr 28, 2011 6:29 pm Post subject: |
Yeah that doesn't sound to bad, will it even be driveable without being tuned? I know it should run pretty bad |
