SlackerTA Member
Posted: Sat Mar 05, 2011 12:08 am Post subject: 21mm rear sway bar |
| My new Firebird has a tiny little bar and I already have poly bushings for a 21mm bar so I'd like to upgrade. Anybody got one sitting around? |
Posted: Sat Mar 05, 2011 7:50 am Post subject: |
I've got the set of bars here off of my '85 Z28.
The rear is either 21mm or 24mm, I haven't checked. It's nearly as big if not equal to the WS6 bar that replaced it.
Are you coming to dyno? |
SlackerTA Member
Posted: Sat Mar 05, 2011 9:30 am Post subject: |
Ya, whether I dyno or not is undecided but I should be there. _________________ '91 Firebird - LO3, 700R4, 2.73 gears
'85 Trans Am - SOLD
'95 Z28 - SOLD |
Posted: Sat Mar 05, 2011 9:56 am Post subject: |
Aaron, yours might be 23mm. I have a set from one of Luke's Z28 parts cars to put on my 92. They measure 32/23mm, I just need a set of bushings - but I'd like to do all of the bushings when I do. _________________ 92 Camaro
Posted: Sat Mar 05, 2011 1:05 pm Post subject: |
Al you are correct. It appears to be a 23mm.
A 24mm wrench fits tight on my WS6 bar, but loose on the Z28 bar. However a 22mm wrench wont fit over either.
Slacker, it's yours for a couple bucks at dyno. |
SlackerTA Member
Posted: Sat Mar 05, 2011 2:10 pm Post subject: |
Sounds good to me.  _________________ '91 Firebird - LO3, 700R4, 2.73 gears
'85 Trans Am - SOLD
'95 Z28 - SOLD |
SlackerTA Member
Posted: Sun Mar 13, 2011 8:58 pm Post subject: |
Thanks again, Aaron. I need to install all these suspension parts I've been collecting as I'm running out of room in my storage closet.  |
