Posted: Thu Feb 24, 2011 8:44 pm Post subject: Last minute dyno mods.. |
So everyones being hush hush.. What are you all up to? or is it really top secret?  |
Posted: Thu Feb 24, 2011 9:00 pm Post subject: |
| I know what a certain somebody is doing with their big block, but I can't tell. |
Whiskeychick Member
Joined: 19 Sep 2010 Posts: 225 Location: Penticton BC
1987 Pontiac GTA
Posted: Thu Feb 24, 2011 9:39 pm Post subject: |
Im not hush hush just not doing anything exciting  _________________ 1987 - Trans am GTA, hooker headers, Borla catback, Cat delete, CAI, 9.6 @ 75mph 1/8mile
2008 - Mini Cooper Clubman S, Hot Chocolate on Hot Chocolate Lounge Leather  |
Posted: Thu Feb 24, 2011 9:50 pm Post subject: |
| I found an LS9 for cheap. |
Posted: Thu Feb 24, 2011 9:51 pm Post subject: |
Was just reading about a 5.3 putting out 500hp with an edelbrock carb on top... well. it was 480 with the carb and 500 with the efi!  |
Posted: Thu Feb 24, 2011 10:14 pm Post subject: |
| iansane wrote: | | I found an LS9 for cheap. |
Is this going where I think it's going?  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Feb 24, 2011 10:49 pm Post subject: |
| DBL_TKE wrote: | | iansane wrote: | | I found an LS9 for cheap. |
Is this going where I think it's going?  |
In my dreams it is.
Seriously though, I haven't done anything to the bird other than suspension and add a catch can. I doubt I'll be much different power-wise, if at all. I was going to attempt the turbo install but I couldn't get all the parts lined up in time.
| chevymad wrote: | Was just reading about a 5.3 putting out 500hp with an edelbrock carb on top... well. it was 480 with the carb and 500 with the efi!  |
N/A? Wow. Is that wheel or crank? |
Posted: Thu Feb 24, 2011 10:55 pm Post subject: |
I'm assuming crank. Its in a mag article.. so assume cali dyno as well. I dont remember which mag, but the way those articles work its probably in several of them by now.  |
TurdGen1989 Member
Posted: Fri Feb 25, 2011 9:00 am Post subject: |
Some sort of snail attachment? not really sure what it does though.
Ha, Jk just trying to keep it running! _________________ Phil.
GMC High Sierra
Posted: Fri Feb 25, 2011 1:08 pm Post subject: |
| I haven't even driven mine since the Seattle gathering. I'm just hoping she comes to life when I ask her to for the dyno. |
turbo_jimi Member
Posted: Fri Feb 25, 2011 1:16 pm Post subject: |
Gabe and Aaron helped dial in my carb and timing. Nothing else I can really do before dyno day. _________________
Posted: Fri Feb 25, 2011 2:24 pm Post subject: |
My car is actually running! That'll have to be enough for this year! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Feb 25, 2011 6:11 pm Post subject: |
I'll have to see how EBL works for tuning. Seems pretty good for now  _________________ 92 Camaro
Posted: Fri Feb 25, 2011 6:28 pm Post subject: |
Looking at a new muffler. We'll see how funds and time hold out. I'm freakin busy and freakin broke these days. Living good though! One more big side project to finish up and I can relax.
Stock muffler = no flow _________________ A redline a day keeps the carbon away! |
Posted: Fri Feb 25, 2011 6:34 pm Post subject: |
Uh wow! By the time the exhaust figures out which way to come out of that thing is it even moving?
I thought the dual in dual out crossflow i had sucked.
I've got a spare used 3" flowmaster. Doubt you could use it, but yours by chance if you need it. |
Posted: Fri Feb 25, 2011 6:40 pm Post subject: |
I'm not real keen on the flowmaster. They don't "flow" in my opinion either. Plus, with as loud as this thing is now, it's only going to get louder. Flowmaster wouldn't help that equation. Been chatting with Borla about a new "non-aggressive" muffler. _________________ A redline a day keeps the carbon away! |
Posted: Fri Feb 25, 2011 6:44 pm Post subject: |
| Twilightoptics wrote: | | They don't "flow" in my opinion either. |
If you've ever seen a Flowmaster cut apart (which you probably have ) they look pretty much like that stock muffler you showed there. Exhaust comes in and runs smack into a wall.
Great if you like drone, crap otherwise. |
Posted: Fri Feb 25, 2011 6:46 pm Post subject: |
But as Tom Pederson used to say... Free is a very good price! lol But ya.. at some point the flows on my pickup are going away too.
You want non-aggresive.. wait til you hear the Violators I just installed on the blackbird. Turning them the right direction did calm down some of their bark though. |
Posted: Fri Feb 25, 2011 10:48 pm Post subject: |
| RSFreak wrote: | | My car is actually running! That'll have to be enough for this year! |
I believe it when I see you at dyno!  |
Posted: Sat Feb 26, 2011 8:02 am Post subject: |
I was thinking of putting a muffler on the camaro, but why would I add all that extra weight?  |
