91camaro_rs Member
Posted: Thu Feb 03, 2011 9:07 am Post subject: leaky trans |
My tranny was leaking and it looked like thr pan replaced the gasket checked the dipstick tube tv cable and cooler lines and they are fine, what else could be leaking? Because it still leaks... _________________
91camaro_rs Member
Posted: Thu Feb 03, 2011 12:26 pm Post subject: |
Leakin in the front _________________
MrMike98 Member
Posted: Thu Feb 03, 2011 12:45 pm Post subject: |
sounds like the front lip seal for sealing the torque converter.. have you ever had TQ removed from tranny and NOT replaced front lip seal?? if so thats probably the issue . or less likely is the pump gasket/oring-
either case requires u to remove tranny. |
Posted: Thu Feb 03, 2011 4:24 pm Post subject: |
If it's the front, its the tc seal. _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 03, 2011 6:45 pm Post subject: |
| Twilightoptics wrote: | | If it's the front, its the tc seal. |
Most likely, but he needs to pull the tc inspection cover off and stick a torch up in there to be sure.
I had an leaking AOD4 one time that looked like a front seal. Turned out to be a warped pan lip. |
kurfbird Member
Posted: Thu Feb 03, 2011 7:49 pm Post subject: Seals |
There is also a front seal around where the bolts on the front of the trans goes. I had to go to a tans shop to get it looks like a rope seal. Big circle.
Did it to my 92 bird car. replaced the torque coverter seal twice then found out what it was leaking from. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
91camaro_rs Member
Posted: Thu Feb 03, 2011 11:00 pm Post subject: |
| aaron_sK wrote: | | Twilightoptics wrote: | | If it's the front, its the tc seal. |
i forgot thats what you call a flashlight, for a second i was like am i really supposed to take a torch to it? hahaha ill take a look at it this weekend _________________
Posted: Thu Feb 03, 2011 11:08 pm Post subject: |
| 91camaro_rs wrote: | | i forgot thats what you call a flashlight, for a second i was like am i really supposed to take a torch to it? hahaha ill take a look at it this weekend |
Mountain man has his own vernacular. |
91camaro_rs Member
Posted: Thu Feb 03, 2011 11:27 pm Post subject: |
yeah, i have begun to realize that the past few weeks lol _________________
