nonsensekid20 Member
Posted: Fri Jan 14, 2011 11:10 am Post subject: Lowering my car on a budget |
And the budget is 0 dollars. hahah.
So can I just cut the springs to lower it? Or do I have to start changing a bunch of stuff? |
Posted: Fri Jan 14, 2011 11:23 am Post subject: |
"Changing stuff" fixes some of the the problems associated with lowering. Technically you don't need to do anything but your rear axle will be a bit lopsided in the fenders and the rear control arms will probably be at an undesirable angle. At the very least.
Yes you can just cut your springs. I have cut springs on the back of my car. Just do it correctly with a cut off wheel or something similar that won't introduce a lot of heat into the springs. (heat changes springrate.) _________________
Posted: Fri Jan 14, 2011 11:28 am Post subject: |
The least amount of things I have to change the better. Now that I'm looking at it my car seems pretty low. Maybe thats just because I had it on jackstands forever.  |
RK82 Member
Joined: 27 Jul 2008 Posts: 168 Location: vancouver B.C
1982 Pontiac Trans Am
Posted: Fri Jan 14, 2011 11:31 am Post subject: Re: Lowering my car on a budget |
| nonsensekid20 wrote: | And the budget is 0 dollars. hahah.
I cut the springs in my car, just make sure you don't cut to much off start with 1/2 a coil if it still to high cut more, I cut 1 1/2 coils first try now my car sits way to low, the bottom of the k-member is only 3" from the ground. |
Posted: Fri Jan 14, 2011 11:41 am Post subject: |
Whoa, thats pretty low. haha. I think if I go too much lower than it is now my y pipe will hit the ground.  |
Posted: Fri Jan 14, 2011 2:35 pm Post subject: |
You will have to get a front end alignment, so if the budget is 0. Well, sorry.
You can cut coils. On the front, the first 1/2 coil nets you nothing. Starting at about 5/8 to 3/4 coil cut off, it starts going FAST. And like Ian said, do it with a cut-off wheel. |
