Grinding in the rear end?
nonsensekid20
PostPosted: Wed Jan 12, 2011 9:14 pm    Post subject: Grinding in the rear end? Reply with quote
Sad So we went to the gas station and whilst driving i heard a grinding in the rear end. It wasnt all the time, just when I hit the throttle.
Bad rear end? Or simply no fluid?
PostPosted: Wed Jan 12, 2011 9:40 pm    Post subject: Reply with quote
If you got no fluid I'd say yes, the rear is bad or gonna be real quick! Wink
camarokid
PostPosted: Wed Jan 12, 2011 10:49 pm    Post subject: Reply with quote
might be a bearing, if its only while accelerating its load related,
the 10 bolt is famous for cracked pinion teeth is ya hammer on it hard, so that another possibility
does it change turning left or right?
Camaro Kid
1969 camaro sport coupe resto project, 28,000 mi
nonsensekid20
PostPosted: Thu Jan 13, 2011 11:18 am    Post subject: Reply with quote
yeah i noticed when I was turning out of my friends drive way it did it. and when i turned at a stop sign.
PostPosted: Thu Jan 13, 2011 4:47 pm    Post subject: Reply with quote
If you hear grinding from your rear end then you need to see a doctor immediately.
If you hear grinding from the rear axle then you might check the pinion bearing. As far as fluid, there's an easy way to find out.... check it. Wink
PostPosted: Thu Jan 13, 2011 5:40 pm    Post subject: Reply with quote
If it's turning only, look at wheel bearings. If it's acceleration (forward load) or coasting (rearward load) look at gears/pinion bearings.
nonsensekid20
PostPosted: Thu Jan 13, 2011 8:41 pm    Post subject: Reply with quote
Well we took off the cover, and it seemed to be a little bit low. But I figured out since the load of the car was on the front more the exhaust pipe was rubbing on the ujoints. No damage, just a little grinding. There was a lot of metal on the magnet that's on the cover. Idk if that's normal or not. If the right wheel spins one way, but the other spins the opposite way, what kind of differential in it?
RK82
1982 Pontiac Trans Am
PostPosted: Thu Jan 13, 2011 9:09 pm    Post subject: Reply with quote
open
nonsensekid20
PostPosted: Thu Jan 13, 2011 9:28 pm    Post subject: Reply with quote
Alright thats what I originally thought. I got a little excited when I saw both tires moving. hahaha.
But I'm pretty sure all that grinding noise i was hearing was from the u-joint rubbing on the exhaust pipe when I hit the gas or turned. hm, how to fix this.
anyone think it could just be my shocks are worn? Like when you hit the gas the front end wants to fly up causing the u joint to be closer to the exhaust by putting more load on the rear end.
PostPosted: Thu Jan 13, 2011 10:10 pm    Post subject: Reply with quote
If there's an obvious wear mark on the exhaust, my guess would be that the muffler hangers are crapped out, or gone altogether. That will cause the over-axle pipe to bang on the driveshaft or the panhard bar.
nonsensekid20
PostPosted: Fri Jan 14, 2011 10:59 am    Post subject: Reply with quote
Yeah there's some wear on it. not a lot considering it's a brand new galvanized 3" pipe. Confused
I tried just moving the pipe out of the way. hahaha. yeah rightt. I think when he installed it he just bent it so its too close to the pipe. Right now the car is on jack stands, but when I jacked up the front of the car more, it moved the ujoint out of the way from the exhaust. Confused
How do I know the shocks are shot?
RK82
PostPosted: Fri Jan 14, 2011 11:20 am    Post subject: Reply with quote
if there original? its probably time to change them
nonsensekid20
PostPosted: Fri Jan 14, 2011 11:22 am    Post subject: Reply with quote
That's what I was afraid of. Do I have to change them all at once?
RK82
PostPosted: Fri Jan 14, 2011 11:33 am    Post subject: Reply with quote
its a good Idea to, but you don't have to
nonsensekid20
PostPosted: Fri Jan 14, 2011 11:39 am    Post subject: Reply with quote
Depending on which ones aren't good I'll just change the sides that are bad. The front ones should only be bad for now. But idk yet.
Any suggestions on a good cheap brand?
RK82
PostPosted: Fri Jan 14, 2011 12:53 pm    Post subject: Reply with quote
monroes are good if you just want stock replacement, I'd suggest you wait, save your money and replace all four with a good performance set. I am in the process of putting KYB AGX adjustable struts and shocks in my car.
nonsensekid20
PostPosted: Fri Jan 14, 2011 4:19 pm    Post subject: Reply with quote
I was looking at the KYB G2's. Not super expensive.
PostPosted: Fri Jan 14, 2011 5:25 pm    Post subject: Reply with quote
KYBs period for OE or slightly better performance/longevity.
Replace in pairs. IE Fronts(struts both sides) or Rear (shocks both sides).
PostPosted: Fri Jan 14, 2011 5:38 pm    Post subject: Reply with quote
*two cents*
Monroe. Thumbs down
KYB if you're on a budget. Thumbs up
I'm thinking you need to take a trip back to the exhaust shop if the welder put the pipe that close to the driveshaft. Or just buy my Magnaflow SS catback. Very Happy
PostPosted: Fri Jan 14, 2011 5:45 pm    Post subject: Reply with quote
I'll agree with Paul on the KYB's. I"ve got them on the front of my bird and they work great, and the price is nice too.
