2500 no start issue
91camaro_rs
PostPosted: Mon Jan 03, 2011 10:27 am    Post subject: 2500 no start issue Reply with quote
ok so my friend has a 93 2500, she said she was driving it and went to put it in reverse and it just died and hasnt started since, tried to jump it and that didnt work, battery was tested and its good, i tested for spark and there is no spark... i swapped out ICM, distributor, and coil, (out of my spare parts) and still not starting, what else would cause this thing to have no spark?
PostPosted: Mon Jan 03, 2011 12:56 pm    Post subject: Reply with quote
Fuse to spark system?
Fuse to ecm?
bad ground to block
Are the injectors spraying?
91camaro_rs
PostPosted: Mon Jan 03, 2011 7:08 pm    Post subject: Reply with quote
Yes in jectors are spraying
Ill check the fuses
MrMike98
PostPosted: Tue Jan 04, 2011 11:41 am    Post subject: Reply with quote
a long shot:
VATS or
something associated with park/neutral start electrics around shifter base switchs, maybe something loosened up....
good luck
Mike
PostPosted: Tue Jan 04, 2011 12:21 pm    Post subject: Reply with quote
TBI?
Check ign power to coil and power while cranking.
91camaro_rs
PostPosted: Tue Jan 04, 2011 11:23 pm    Post subject: Reply with quote
she ended up having it towed to the shop, and it was the ICM, thats wierd cause i swapped it out and it still didnt start
PostPosted: Wed Jan 05, 2011 9:11 am    Post subject: Reply with quote
A known "good" part swapped in will only tell you if it works. It wont tell you if it doesn't work.
