Posted: Sun Feb 06, 2011 10:10 am Post subject: Wire Harness Pigtails |
I need both connectors for the A/C compressor. The round one for the high pressure switch on the back side of mine has a broken locking mechanism and can easily slide off. The flat one on the front for the clutch switch I had to cut off and splice on a couple of female spades as a temporary fix. _________________ 92 Camaro
Posted: Sun Feb 06, 2011 10:23 am Post subject: |
| Al I've got a couple harnesses here from aircon cars, but I can't tell offhand what connectors you need. Any pics? |
Posted: Sun Feb 06, 2011 10:50 am Post subject: |
Not really necessary. What I have works for now, so no hurry either. The round one is pretty universal, the other is the one with the diode between the two terminals. Maybe I can make it out for one of the "mini-events" and pick through what you have  |
Posted: Sun Feb 06, 2011 1:17 pm Post subject: |
I have my TPI harness completely stripped and I won't be needing most of it. I think I know which plugs you're talking about. I'll go look later on and post some pics and you can tell me if they're the correct ones. If so I'll bring them to the dyno. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
