nonsensekid20 Member
Posted: Thu Dec 09, 2010 12:01 pm Post subject: Nice website |
car-parts.com
need parts? there ya go. ahha |
Posted: Thu Dec 09, 2010 12:06 pm Post subject: |
Unfortunately not every junkyard is subscribed to that, but it's getting better. _________________ A redline a day keeps the carbon away! |
Posted: Thu Dec 09, 2010 1:05 pm Post subject: |
Ive known about that site for atleast 7 years.
Correct that not all are on it.
Also, dont email them.....slower then dirt! Call!!! |
Posted: Thu Dec 09, 2010 6:19 pm Post subject: |
Emailing is yard specific though. _________________ A redline a day keeps the carbon away! |
Posted: Thu Dec 09, 2010 8:13 pm Post subject: |
Ehh... they tend to cater to yards with expensive pre-pulled parts, which is their business. I tend to prefer the redneck pull-your-own places. Makes it more fun.  |
Posted: Mon Dec 13, 2010 11:45 am Post subject: |
| True. Unless you go to a yard looking for a steering column that you called before hand to check if they had it, said they did, drove all the way out to Shelton from Gig Harbor, just to find out they really didnt have one. Well they did have ONE. But it was rendered useless because all it was was a basic rod. So you really drove all the way out to Shelton, for nothing. COOL |
Posted: Mon Dec 13, 2010 8:32 pm Post subject: |
Should have just gone to Tumwater.  |
Posted: Mon Dec 13, 2010 8:56 pm Post subject: |
I think we called them and they didnt have one. grr.
Anyone know of a high/low beam switch for a 91?
The one on the 85 steering column Luke gave me is different. |
Posted: Mon Dec 13, 2010 9:02 pm Post subject: |
| The switch itself is an off-the-shelf part. Should be able to get it anywhere. |
Posted: Mon Dec 13, 2010 9:09 pm Post subject: |
Is he referring to the actual switch, or the multifunction lever (blinker stem)? The switch should be the same through the years IIRC, but there are differences in the lever. _________________ 92 Camaro
Posted: Mon Dec 13, 2010 9:16 pm Post subject: |
| If you just want the stalk, yank yours out, take it down to Pull a Part, and have it tagged before you go into the yard. Then just start pulling stalks out of all the Chebbies till you find one that has the same d*** on it. |
Posted: Wed Dec 15, 2010 8:48 pm Post subject: |
| I'm only looking for the module that goes in between the lever and the rod that leads to the switch for the high/low beams. Anyone know what that's called? |
