Triple gauge pod
nonsensekid20
PostPosted: Wed Dec 01, 2010 7:29 pm    Post subject: Triple gauge pod Reply with quote
Just bought a tach and 3 gauges from summit. WHOO!
Does anyone have experience with the triple gauge pods? not really sure how they go together. hahah
PostPosted: Wed Dec 01, 2010 10:41 pm    Post subject: Reply with quote
All the ones I've seen are "covers" that go over the stock a-pillars. My dual pod was like that. I had to cut a hole in the factory trim piece to feed the wires through and rivet/screw/whatever the pod to the pillar piece. Fairly easy, just don't do it too low otherwise it hits the dash. Smile
I think I've seen the triple pods that go the entire length of the pillar piece but they're still just covers.
PostPosted: Wed Dec 01, 2010 10:56 pm    Post subject: Reply with quote
Why doesn't someone make one that replaces the stock trim piece with the pods molded in? Confused
BluFbdy
PostPosted: Wed Dec 01, 2010 11:59 pm    Post subject: Reply with quote
because that would be intelligent lol id buy one in a heart beat, i didnt wanna mess with the pillar pod cuz mine are warped to hell and back from being an AZ car, speaking of which...does anyone have a set of black a pillars for a t-top car in decent shape? Mine are driving me insane lol
In any case i went with a triple gauge setup underneath my center vents, flushed them back into the dash as far as i could, it looks pretty clean
PostPosted: Thu Dec 02, 2010 5:04 am    Post subject: Reply with quote
I thought the one I had was full replacement?
Anyway, I have a tripple in mine. It makes removing the dash pad PITA!
PostPosted: Thu Dec 02, 2010 8:37 am    Post subject: Reply with quote
The full pillar autometer one is a cover and yeah PITA to remove the dash pad. You drill holes and install little trees to hold it up. Buy extra trees, cause they dont hold well, and once they've come apart they're pretty much dead.
PostPosted: Thu Dec 02, 2010 9:14 am    Post subject: Reply with quote
Ok, maybe thats why I'm not overly happy with fitment. I ended up cutting n drilling mine and making it install like a stock vert piece.
PostPosted: Thu Dec 02, 2010 10:23 am    Post subject: Reply with quote
Aren't the Vert pieces different? I don't know that they offer a Vert specific piece.
PostPosted: Thu Dec 02, 2010 11:18 am    Post subject: Reply with quote
Yes n No.
The vert pieces where t-top ones cut down with a hole drilled/c-sunk to stay in place. So thats what I did with my tripple pod.
PostPosted: Thu Dec 02, 2010 12:10 pm    Post subject: Reply with quote
The full pillar autometer one is a cover and yeah PITA to remove the dash pad. You drill holes and install little trees to hold it up. Buy extra trees, cause they don't hold well, and once they've come apart they're pretty much dead.
I ditched the christmas trees and used black rivets. Since the 'vert trim piece comes completely out with just easily accessible two philips screws I figured it was easy to permanent mount the cover to the trim piece.
PostPosted: Thu Dec 02, 2010 12:18 pm    Post subject: Reply with quote
You have 2 in yours? Or are you saying 1 each side?
PostPosted: Thu Dec 02, 2010 5:27 pm    Post subject: Reply with quote
Nice Idea, but ian, what if you have to service a gauge? Certain brands.... cough:innovate:cough have a history of failing.
nonsensekid20
PostPosted: Thu Dec 02, 2010 9:10 pm    Post subject: Reply with quote
So I just test fitted it, and the studs on the back hit the molding. grr. should i cut the studs down or what?
PostPosted: Thu Dec 02, 2010 9:21 pm    Post subject: Reply with quote
If you mean the studs on the back of the gauges, you can cut them. Just don't go crazy, in case you want to install them elsewhere.
PostPosted: Thu Dec 02, 2010 11:00 pm    Post subject: Reply with quote
Pull two screws out of a-pillar piece, unplug spade terminal'd harness to gauges at the base of the a-pillar. Or do you mean take it out of the pod? I use autometer gauges so I'd just unscrew the two nuts on the back and the ubracket that holds them comes loose and the gauge slides out the front.
How else would you take it out? Very Happy
Even still, they've been in the car for 5 years now and I haven't even touched the bulbs. Now that I say that tomorrow I'm going to notice one is out. Laughing
PostPosted: Thu Dec 02, 2010 11:02 pm    Post subject: Reply with quote
I have a dual gauge pod. I thought about a trying a triple pod on the driver side and grafting a single pod to the passenger side to mount tweeters there but the angle was all wrong and I'm horrible with plastic molding.
nonsensekid20
PostPosted: Fri Dec 03, 2010 11:44 am    Post subject: Reply with quote
Yeah thats how the back of my gauges look. Autometer Cobalt.
Those brass studs that hold the harness in place; the left one hits the inside edge of the pod. so the harness wont slip over the gauges, and i can't tighten it down. The gauges don't even sit all the way down in the pods.
So I can trim those studs a little bit?
nonsensekid20
PostPosted: Tue Dec 07, 2010 11:16 am    Post subject: Reply with quote
so did you trim the studs when you got it where you wanted it?
PostPosted: Tue Dec 07, 2010 3:53 pm    Post subject: Reply with quote
Honestly its been way too long for me to remember. It doesn't sound out of the realm of possibility though. That would've been after I cut the factory trim piece so it was passed the point of no return. Smile Just don't trim it too short and you'll be fine. Thread the nut on it and then cut so when you unscrew the nut it'll somewhat fix the threads. You'll still need to clean them up with a knife or file or something.
nonsensekid20
PostPosted: Tue Dec 07, 2010 7:17 pm    Post subject: Reply with quote
Alright sounds good. I've got a guy working on it right now. He does fabricating and stuff so I think he'll come up with somethin. haha
