Posted: Tue Sep 07, 2010 6:21 pm Post subject: 10 Bolt Disc Brakes w/ backing plates $$?? |
No idea what these are worth. Pads are almost new. Comes with calipers, backing plates, pads, rotors. I have the long e-brake cables SOMEWhere burried in the storage unit. If I find em we can work something out, but for now the box is for sale.
Offers? _________________ A redline a day keeps the carbon away! |
Posted: Tue Sep 07, 2010 6:40 pm Post subject: |
| Any idea if they might fit a 8.5" 10 bolt? |
Posted: Tue Sep 07, 2010 7:08 pm Post subject: |
They came off an '87
I have no idea really if they'd fit the larger 10 bolt. _________________ A redline a day keeps the carbon away! |
Posted: Wed Sep 08, 2010 8:33 am Post subject: |
| Knowing gm they probably carried over as many parts as possible. Just wondering if the bracket is similar really. I'm finding that people now think 2nd gen rear ends with discs and/or posi are gold plated. It's not a priority but something I'd like to add. When I get home I'll see if i can measure my spare 3d gen rear and compare to the 2nd. |
Posted: Sun Oct 10, 2010 3:53 pm Post subject: |
| Do you know what the bolt pattern measurements are on the backing plates? I measured my 8.5 10 bolt, then went to measure the 7.5... umm.. ya.. the drum brake rears dont have the 4 hole pattern on the 7.5s. |
Posted: Sun Oct 10, 2010 7:09 pm Post subject: |
I'll go measure afterwork sometime this week.
I know there are atleast two different 7.5" thirdgen housing bolt patterns. _________________ A redline a day keeps the carbon away! |
Posted: Sun Oct 10, 2010 7:24 pm Post subject: |
| Thanks. From the info i'm finding 4th gen LS rear brakes and s10/trailblazer rear brakes are direct bolt on's with no problems. So I think the 3d gen stuff should work too. |
Posted: Tue Oct 12, 2010 8:23 pm Post subject: |
2 7/16" Vertical top to bottoms
2 11/16" bottom holes horizontally measured
3 1/8" top holes horizontally measured.
Makes a trapezoid of sorts.
_____
\____/ _________________ A redline a day keeps the carbon away! |
Posted: Tue Oct 12, 2010 8:26 pm Post subject: |
| Thanks Paul. Off the top of my head it sounds right, but I'll try to measure tomorrow myself. |
Posted: Wed Oct 13, 2010 6:25 pm Post subject: |
Ok. I think its the same. My measurements were off a 1/16th.. but i'm measuring with the backing plate on and with a rusty caliper thats hard to read.
So.. any idea what you want at all? I'd like to have them, but its rent time again and this project wasnt high priority. More like since they're for sale maybe I should pick them up. PM me what you think. |
Posted: Wed Oct 13, 2010 6:31 pm Post subject: |
Doesn't exactly seem to be a hot ticket item. I can wait for when you've got cash.
Always bad at the what's it worth to ya, what do you want for it battle. _________________ A redline a day keeps the carbon away! |
Posted: Wed Oct 13, 2010 6:38 pm Post subject: |
| Same here. I hate to piss someone off, so I usually hurt myself on the deal. |
