Dan Johnson Member
Joined: 26 Feb 2010 Posts: 29 Location: Poulsbo, WA. 98370
Posted: Fri Oct 01, 2010 6:25 pm Post subject: Fan Shourd |
I need a good fan shourd for my 91 RS 305, the pop rivets and bubble gum on mine are coming apart. Dan (might make it to Ian's sat afternoon) _________________ DJ |
Posted: Fri Oct 01, 2010 6:38 pm Post subject: |
Shoot turbo_jimi a message. I think he still has a spare in his shed. |
Dan Johnson Member
Posted: Fri Oct 01, 2010 6:49 pm Post subject: |
did. thanks _________________ DJ |
91camaro_rs Member
![](images/avatars/16244201154a82fd8aac78b.jpg)
Posted: Sat Oct 02, 2010 12:07 am Post subject: |
i have the part that goes on the top of radiator i think its the shroud. i have one for elec and clutch fan _________________
Posted: Sat Oct 02, 2010 6:51 am Post subject: |
The shroud is actually a two-piece unit, Luke. Upper and lower. |
![](images/avatars/1674366422470d93dc81544.jpg)
Posted: Sat Oct 02, 2010 8:08 am Post subject: |
If that was parted from a TPI car, isn't it a dual fan setup? Or are some of those singles? Dan's TBI car needs a single fan shroud. _________________ 92 Camaro
![](http://www.uzzisoft.com/randomsigscript/alhasse.jpeg) |
turbo_jimi Member
![](images/avatars/18919800894ea724a27ad8d.jpg)
Posted: Sat Oct 02, 2010 9:15 am Post subject: |
TPIs had single and dual fans installed, depending on the year. I have the single upper, but not the lower. _________________
Dan Johnson Member
Posted: Sat Oct 02, 2010 9:31 am Post subject: |
I need both upper and lower _________________ DJ |
Posted: Sat Oct 02, 2010 9:37 am Post subject: |
I'm stopping by the Poulsbo yard on my way home (I'm at work ), I'll take a look and see if there are any. _________________ 92 Camaro
