nonsensekid20 Member
Posted: Tue Oct 12, 2010 7:33 pm Post subject: Nitrous Oxide |
| So, my 350.. I'm not quite sure what kind of pistons and stuff is in there because I bought it as a crate motor. That being said, what's the highest HP shot of N20 I can put in? |
Posted: Tue Oct 12, 2010 7:43 pm Post subject: |
You can put whatever size you want in hehe. Might not have the desired results though
Which crate engine is it do you know? Is it a GM crate or...?
Posted: Tue Oct 12, 2010 7:45 pm Post subject: |
| It was a crate motor we bought from Bowtie Performance. So I'm pretty sure it's a refurbished block with new parts. So I have no idea what the guy put in besides a bigger cam. hahah |
Posted: Tue Oct 12, 2010 7:47 pm Post subject: |
| There's alot of important things you'll need to know to figure this out. Forged pistons? aftermarket rods? forged crank? What compression? |
Posted: Tue Oct 12, 2010 7:53 pm Post subject: |
| chevymad wrote: | | There's alot of important things you'll need to know to figure this out. Forged pistons? aftermarket rods? forged crank? What compression? |
This is what I need to know. haha. I guess I'll have to call the guy that built the motor and see if he remembers or has it on file. |
Posted: Tue Oct 12, 2010 8:03 pm Post subject: |
How long ago did you buy it? Any way to figure out which setup it is?
For general info, the nitrous kit I had previously had two setups; 110hp and 150hp. The 110 was for a 305 TPI. So most LB9 were 9.3:1 compression ratio. The 150 shot was for the 350 TPI (L98 was 9.3:1 or 9.5:1 I believe). I started with the 110 and when everything was running correctly I bumped the jets to 150. A 100 or so shot on just about any V8 is usually pretty safe ASSUMING everything else is taken care of... proper fueling, good spark, good exhaust, etc. etc.
Maybe a better way to start this out would be, what are you hoping to achieve with the nitrous? Just for giggles or you have a drag race time in mind? Something else?...
-Schultzy |
Posted: Tue Oct 12, 2010 10:00 pm Post subject: |
You should have gotten a full receipt and a cam card when you bought the crate. If you lost it, the shop should have one on file for the warranty.
Assuming you lost your receipts, Sumner ain't that far. Just drive out there and see what they have for it. |
Posted: Thu Oct 14, 2010 10:23 am Post subject: |
| aaron_sK wrote: | You should have gotten a full receipt and a cam card when you bought the crate. If you lost it, the shop should have one on file for the warranty.
This is true. I didn't find the cam card. and the reciept just says crate motor. Nothing about internals. But if I still can't find the cam card I'll just go to Bowtie Performance and get a new one. |
Posted: Thu Oct 14, 2010 4:32 pm Post subject: |
Convential wisdom on a stock motor in good condition is 20hp per cylinder, so a 160 shot should be safe. I read that somewhere, wish I remember where.
EDIT: I got that from an interview in Chevy High Performance with the owner of Texas Nitrous Technologies. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
izcain 9sec Club
Posted: Thu Oct 14, 2010 5:36 pm Post subject: |
Just remember if there is any weakpoints in the car it will find them quickly lol _________________
9.17 @ 148 |
Posted: Thu Oct 14, 2010 8:24 pm Post subject: |
That is a great point Zac. Most have found that these cars were engineered for a certain power level. Once you start going beyond that, you discover limits on transmission, rear end, etc. Just something else to think about. The expense often goes beyond the nitrous kit
It is fun though. I was always disappointed that the nitrous didn't give me an 8 speed and cause my floor board bolts to loosen
-Schultzy |
Posted: Thu Oct 14, 2010 10:41 pm Post subject: |
And you gotta be careful not to blow the welds on your manifold!  |
corey davidson Member
1986 Chevrolet Camaro
Posted: Fri Oct 15, 2010 12:21 am Post subject: |
by Bowtie performance do you mean the one in turner well the out side of turner _________________ real men are covered in oil and grease |
Posted: Fri Oct 15, 2010 4:26 am Post subject: |
| RSFreak wrote: | And you gotta be careful not to blow the welds on your manifold!  |
Because now me and the mad scientest have to rip apart the engine block. |
izcain 9sec Club
Posted: Fri Oct 15, 2010 8:48 am Post subject: |
He could have slowed down he saw the danger to manifold signal lol
But on a serious note Once you begin using it it's like an addiction there will always be another item for the kit or expanding off of what you have and lets not even get into all the flowing fuel pressures and jetting you can get into lol
Depending on what your plans are just try to build some overkill into the system. This is coming from the guy with the 400hp plate kit with all the accessories and a dedicated fuel supply but only has been utilizing a 100 hit out of the kit. Make it to where when you want/can step the power up to higher levels as the engine is built stronger you can. _________________
9.17 @ 148 |
Posted: Fri Oct 15, 2010 4:02 pm Post subject: |
| 91RSVert wrote: | | RSFreak wrote: | And you gotta be careful not to blow the welds on your manifold!  |
"Granny shiftin’, not double clutchin’ like you should. You’re lucky that hundred shot of NOS didn’t blow the welds on your intake."  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Oct 15, 2010 8:06 pm Post subject: |
I'm likin the quotes from The Fast and the Furious. hahaha. Ask any racer. Any real racer. It doesn't matter if you win by an inch or a mile. winnings winning. haha.
Bowtie Performance in Sumner. |
Posted: Fri Oct 15, 2010 10:18 pm Post subject: |
I wish I could find my copy of Car Craft which featured the 10 stupidest quotes from Fast and Furious!  |
Posted: Sat Oct 16, 2010 9:57 pm Post subject: |
| RSFreak wrote: | I wish I could find my copy of Car Craft which featured the 10 stupidest quotes from Fast and Furious!  |
That's hard to choose. The entire movie was awesomely bad one liners. I think I can quote the entire thing! |
izcain 9sec Club
Posted: Sun Oct 17, 2010 4:53 pm Post subject: |
Just dont push to much NOZ thru it other wise "what do you plan on racing with? Hope and dreams?"
9.17 @ 148 |
