![Cascade Crew Forum Index](templates/subSilver/images/logo_phpBB.gif) |
Cascade Crew Message Forums
BluFbdy Member
Posted: Fri Nov 12, 2010 1:13 am Post subject: need smog pump info asap |
So my jegs order just showed up, got a new msd cap and rotor, bosch platinum plugs (for their length) and jegs spark plug wires, now I've been putting off this tune up for too long because I had to do the spark plugs right after I installed my headers and I just wanted to shoot myself, the driver side was cake but I spent a good hour on the passenger side because the smog pump lines...
So I want to bypass the smog pump with a rerouted belt, I looked on TGO and it says I need a 96.8" belt, now I've been told its more expensive because its an odd size, but I've also been told you can run a 97" belt and save $, anyone done this? If iim gonna pull the air tubes out of my way to do my plugs I might as well just get rid of them entirely and with money being tight a belt is cheaper than a delete pulley lol
I know removing the pump is frowned upon but I don't run emissions anymore and I want to unclutter the engine bay plus I had a gutted pump in az so it wasn't even working and I had under half the allowed ppm lol long story short it froze on me so I tossed another one on and now its time to shed the clutter
I need a P/N for the belt, TGO says dayco 968k6 but shucks and autozone show no listing for it and I don't wanna run a duralast or valucraft belt again so if someones got that its be appreciated
TIA _________________ If you expect a kick to the balls and get a slap to the face its still a victory
![](http://i49.photobucket.com/albums/f294/master_disasterX9/Camaro/BluFBdy.jpg) |
Posted: Fri Nov 12, 2010 6:15 am Post subject: |
Take an old belt, cut it, wrap it around, mark it, then run it out out flat and measure it with a tape. Only way to know for sure.
NAPA should be able to sell you a decent Gates belt. Remember that the part number is the length (in inches, plus a decimal point) and then the number of ribs. It's not unique to the brand.
Also remember that there is a little bit of slop in the tensioner, so while you may have trouble finding a 968/6, a 965/6 may work just fine.
BTW, length or not, Bosch is junk. ![Razz](images/smiles/icon_razz.gif) |
91camaro_rs Member
![](images/avatars/16244201154a82fd8aac78b.jpg)
Posted: Fri Nov 12, 2010 8:51 am Post subject: |
Idk if you have v-belt or serp but I have a serp setup wit the a/c and smog pump bypassed and the belt I use is from shucks part number K060980. It says its 98 5/8's _________________
BluFbdy Member
Posted: Sat Nov 13, 2010 8:26 pm Post subject: |
Well that's odd I used a 96 and 1/8th belt, it was tight but it fits and hasn't been tossed yet and I only bypassed the smog pump, it was a PAIN trying to break the pulley bolts loose lol
In any case its all done, smog is gone, new plugs, wires and rotor/cap it definitely makes a difference I only burned 1/8 tank going to silverdale and back, better throttle response and the exhaust isn't as rich, you should see those plugs they're so beyond toasted I dunno how my car was running[/list] _________________ If you expect a kick to the balls and get a slap to the face its still a victory
