laegion Member
Posted: Sat Oct 16, 2004 12:07 pm Post subject: question about flywheels |
can you swap the clutch and pressure plate from a two piece rear main seal flywheel onto a one piece rear main flywheel? and also is the teeth count on both flywheels the same? basically what I'm getting at is I'm thinking about swapping a roller cam motor into my car but I want to know what I'm going to have to replace besides the flywheel. like the starter or clutch? _________________ 95 vw jetta gl
currently looking for a cheap ninja 250 or 500 or comperable 2cyl sportbike. |
Posted: Sat Oct 16, 2004 12:47 pm Post subject: Re: question about flywheels |
laegion wrote: | can you swap the clutch and pressure plate from a two piece rear main seal flywheel onto a one piece rear main flywheel? and also is the teeth count on both flywheels the same? basically what I'm getting at is I'm thinking about swapping a roller cam motor into my car but I want to know what I'm going to have to replace besides the flywheel. like the starter or clutch? |
Two piece and one piece flywheels are different. The difference is in how they bolt to the crank, thus are no interchangable. The clutch, however, may swap over. I think the disc will but I'm not sure about the pressure plate.
If the flywheels come off a thirdgen, they are 153 tooth count and will work with your starter. If you end up with a big flywheel, 168 tooth count, you'll need the big starter. |
laegion Member
Posted: Sat Oct 16, 2004 1:01 pm Post subject: |
thanks for the info
I wonder if the pressure plate will swap as well? because I just bought a brand new clutch and I don't want to try and take it back. i've had it for a while sitting in the box, and shucks sucks so I don't want to have to deal with exchanging if I dont' have to. i'm still not even sure I want to swap blocks, it depends on how much trouble I'm going to have. _________________ 95 vw jetta gl
Posted: Sat Oct 16, 2004 1:18 pm Post subject: |
Everything should swap except for the flywheel. Pressure plate and disc should work. |
laegion Member
Posted: Sat Oct 16, 2004 1:31 pm Post subject: |
awesome! thanks for the valuable info guys! _________________ 95 vw jetta gl
