MrMike98 Member
Posted: Fri Aug 06, 2010 3:08 pm Post subject: painting update |
I thought i would be done by now, NOT.....
front is sanded etc to metal,. with por-15 metal prep. followed by DP-90 epoxy primer, and 2-3 coats 2K heavy build primer.
wow, this takes a lot of work.
any thoughts on how to EASILY remove paint from Urethane bumper covers etc.??
how about wet sanding primer, some say NO, some say u cant get a great job with out wet sand.. ?? im confussed.
thanks
Mike |
Posted: Fri Aug 06, 2010 4:22 pm Post subject: |
Havent found an easy way on the bumpers. I've just sanded them down. As for wet sanding i've been in using the no theory. Primer is supposed to be absorbent like a sponge, doesnt make too much sense to me to get it wet and then try to topcoat.
Most people don't realize the amount of work a paint job requires until they try one themselves. Then you realize those spendy quotes you got are probably not so bad. |
MrMike98 Member
Posted: Fri Aug 06, 2010 4:34 pm Post subject: |
I understand NOW---
the primer, i was thinking the same thing, no water, but it loads the paper faster, so, longer to sand.
on the bumper i am just going to take my 7" sander to them, use a adhishive promoter and prime and paint, these will take as long has the rest of the car to prep. paint.
how about the door's, i am planning to remove them and prep and paint then reinstall, less bending over, all glass is removed etc... are these doors hard to align??
Mike |
Posted: Fri Aug 06, 2010 4:51 pm Post subject: |
| Only because they're heavy as hell. |
MrMike98 Member
Posted: Fri Aug 06, 2010 4:55 pm Post subject: |
so to align doors:
motorcycle jack,
3 people,
case of beer, |
Posted: Fri Aug 06, 2010 4:57 pm Post subject: |
| Since its going to have fresh paint. Hide the beer til afterwards. |
