Free leftovers. Store in sealed containers in the fridge.
PostPosted: Sun Jul 18, 2010 5:23 pm    Post subject: Free leftovers. Store in sealed containers in the fridge. Reply with quote
All going for scrap or in the garbage can by next weekend.
82-89 Camaro dash, drilled for alarm LED, smallish crack in the middle.
Hush panels that hang under the dash (both sides).
Door panels (cardboard part only, not the plastic that goes on top). Grey. Deluxe style that have the swoopy vinyl and carpet, and have map pockets. Very dirty, would need cleaning and fabric re-glued at the very least.
Camaro center console that used to have a silly clock in it. (I think I'm gonna pull the clock out of it, that thing looks kinda cool). Wink
A/C heater controls with vacuum-selector thingy that always leaks, and wiring harness that rarely, if ever, leaks.
Complete vacuum-driven heater box from behind the dash. Has all the ports and lines and tubes and vacuum UFOs and crap.
A/C compressor, v-belt, not seized. May or may not work. Who really knows. It's a crazy world after all. Shrug
2"? Cherry bomb. Painted the color of cherries, but nowhere near as delicious. You have been warned.
Cruise control alien UFO vacuum dealy. Has yet to be called back to the mothership.
Orb of Power! from under the fender. Powerful and round, and wont rust out like a damn can of beans #$%^&*
Two sets of cable-driven mirrors. Not for Dracula, or really really fast cars. Useful otherwise.
Low-rise 85-86-style spoiler. Pins were busted off the center section by stupid redneck previous owners, thus "spoiling" it. Tappy tap tap
700R4 shifter with cover plate.
Front seatbelts from 2nd or 4th-gen car. Blue. Ugly, pug-fugly blue.
Stock master cylinder. Stops the car. That's about all you can expect from Chebbie brakes. No booster, no prop valve.
Auto pedal. Helps with the stopping as mentioned earlier.
LG4 ECM. Thinks about stuff, like how much it wishes it were a 165 ECM instead.
RS grill. Not broken, but has holes drilled for front plate bracket.
There might be more, but I have already begun to drink. Down the hatch
PostPosted: Sun Jul 18, 2010 5:55 pm    Post subject: Reply with quote
Cruise control bracket that mounts down on the frame rail?
PostPosted: Sun Jul 18, 2010 5:57 pm    Post subject: Reply with quote
Bent. Sad
But totally free! Very Happy
Edit: Just went out to the shop to have a look. Only the little feet support things are bent, and they're not bad. Totally usable. Thumbs up
PostPosted: Sun Jul 18, 2010 6:04 pm    Post subject: Reply with quote
Free does not trump bent/broken!!
Wait...how bent? Laughing
PostPosted: Sun Jul 18, 2010 6:09 pm    Post subject: Reply with quote
Yes it does. Pokey pokey I have based my entire life on the cheap/broken theory. How do you think I ended up with your Blazer? Laughing so hard it hurts
See, that's what you get for replying while I edit. Wink
Orb of Power, or vacuum reservoir Very Happy
Mine dangles by the vacuum line as the mounting tabs are both broken off.
PostPosted: Sun Jul 18, 2010 6:13 pm    Post subject: Reply with quote
It's less powerful that way, Al. Squint
Is yours on the driver or passenger side? Mine is on the driver, and I think on the later cars they switched sides (about the time they moved the batteries over) but I don't know if the can itself changed.
Regardless, it's yours. along with that temp gauge that Chris brought up and left in my truck. Laughing
PostPosted: Sun Jul 18, 2010 6:22 pm    Post subject: Reply with quote
I want to check out the dash pad and the center console
I didn't know the orbs were moved. It's on the driver side for both cars, which have batteries on opposite sides, but needed for the 89.
We'll need to set up a meeting for lunch, brews, whatever...
PostPosted: Sun Jul 18, 2010 6:25 pm    Post subject: Reply with quote
Keeping the dash pad. That listing is for the dash assembly itself. Console is yours if you want it.
Actually, I might have been thinking of the charcoal can getting moved. I can't remember. Rolling Eyes
Sounds like a plan. We should get back on this once-a-month thing we had going there.
PostPosted: Sun Jul 18, 2010 6:29 pm    Post subject: Reply with quote
Wasn't that supposed to be today?
How's next Sunday sound?
PostPosted: Sun Jul 18, 2010 6:34 pm    Post subject: Reply with quote
Our poor organizational skills strike again.
Saturday James and I are maybe possibly going to be Portland-bound. Sunday is presumably still open.
PostPosted: Sun Jul 18, 2010 7:23 pm    Post subject: Reply with quote
Whaaaaaaa...??? I wasn't consulted?!?! Shocked
PostPosted: Sun Jul 18, 2010 7:39 pm    Post subject: Reply with quote
Still seeing what's up.
PostPosted: Sun Jul 18, 2010 8:02 pm    Post subject: Reply with quote
See the part about poor planning as mentioned above.
PostPosted: Sun Jul 18, 2010 8:12 pm    Post subject: Reply with quote
I did see a "maybe possibly" in that post. Maybe, Aaron possibly forgot to consult you Laughing Cool
PostPosted: Sun Jul 18, 2010 11:47 pm    Post subject: Reply with quote
if you do end up coming down to portland next Sat, aaron, I'll take the driver's hush pannel and the brake master.
shoot me a PM when your plans are finalized and we can figure out a time/place to meet up.
PostPosted: Mon Jul 19, 2010 5:37 am    Post subject: Reply with quote
Beerfest?
PostPosted: Mon Jul 19, 2010 6:42 am    Post subject: Reply with quote
Will do!
Beerfest?
Err... more of a pick-up-parts-from-Mike's-and-Brandon's fest. However this "beer"fest of which you speak intrigues me greatly. Confused
PostPosted: Mon Jul 19, 2010 6:53 am    Post subject: Reply with quote
http://www.oregonbrewfest.com/
