Posted: Wed Jun 23, 2010 5:57 pm Post subject: Pressure Plate bolts. |
I actually only need one.
had one bust off in the flywheel. If anyone in the portland metro has some sitting in a parts tray, let me know.
Otherwise I'll just make a trek to the junkyard. _________________
fiveoformula Member
Posted: Wed Jun 23, 2010 10:01 pm Post subject: |
| You can get a cheap set in the Mr. Gasket section of the parts store. I got mine there when I swapped trannies. |
Posted: Wed Jun 23, 2010 10:05 pm Post subject: |
"Cheap" and "thing that will chop of your legs if it fails" probably shouldn't really be in the same sentence.  |
Posted: Wed Jun 23, 2010 10:17 pm Post subject: |
My machine shop guy has packages of them for fairly cheap, but they're quality so they won't take your legs off. Maybe you can find some locally? I don't have any extras.  _________________ 84 Camaro Z28 - LS1/T56
fiveoformula Member
Posted: Wed Jun 23, 2010 10:37 pm Post subject: |
Hey theyre a grade 8 bolt, just packaged by Mr. gasket... lol I meant cheaper than say spending 2 bucks to get into pick n pull, locating an F-body with a 5 speed, then spending another hour or more under a car just to take out some bolts. Don't you have a scatter shield anyway Chris? lol (that was a joke)  |
Posted: Thu Jun 24, 2010 5:39 am Post subject: |
Used the Mr. Gasket bolts for years in MANY vehicle personal and at the old shop. No problems.
If one broke, you're doing it wrong or using the wrong bolts.
The lock washers also have to be the black coated hardened kind or they'll split out. _________________ A redline a day keeps the carbon away! |
Posted: Thu Jun 24, 2010 9:35 pm Post subject: |
went with the Mr gasket set.
Thanks anyways guys. _________________
