Posted: Mon Jun 14, 2010 11:19 am Post subject: '87 LB9 |
My old TPI 305 is up for sale, either complete or by part. Block casting number: 14093627. The intake runners and plenum are currently off the engine. If you want the wiring harness or '85 ECU then speak up quick. I'll be hacking into it in a few days.
Has only a couple hundred miles on the power steering pump, very recent tune up, and has quite a few new sensors.
$300 complete OBO. I need this gone ASAP! _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
IROC-stangs Member
Posted: Mon Jun 14, 2010 4:19 pm Post subject: |
how much would you want for the runners/plenum? or just the runners? what condition are they, dented at all? |
Posted: Tue Jun 15, 2010 1:06 pm Post subject: |
TPI base/runners/plenum $150. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
simpson6716 New Member
Joined: 08 Sep 2010 Posts: 12 Location: Adair Village,OR
Posted: Wed Sep 15, 2010 7:28 pm Post subject: |
Hey you got any of this left. I would be interested in some parts off that motor. |
Posted: Sun Oct 03, 2010 11:57 pm Post subject: |
Yup still have everything except the wiring harness. I'm more interested in getting rid of the engine complete, but what are you interested in? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
91camaro_rs Member
Posted: Thu Oct 14, 2010 11:13 am Post subject: |
how was the compression? did it smoke at all? my piston rings are not in good shape, and i have a ton of blowby, was thinkin about just swappin bottom ends, instead of replacing piston rings. how many miles are on it? _________________
Posted: Fri Oct 15, 2010 2:02 pm Post subject: |
I never did do a compression test but as far as I was concerned it was all in pretty good shape. I can't recall ever noticing any smoke on startup. My car had about 150k? When I pulled it, but I know that it is not the original engine. I can send pictures if needed. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
91camaro_rs Member
Posted: Fri Oct 15, 2010 2:08 pm Post subject: |
ok well i found a L03 motor for 200, but i was wondering how much do you want for the LB9 heads and cam? _________________
Posted: Tue Oct 19, 2010 8:52 pm Post subject: |
How's $100 sound for the heads and cam? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
91camaro_rs Member
Posted: Tue Oct 19, 2010 10:12 pm Post subject: |
well im trying to figure out if i should keep the L03 heads or not,but ill get back to ya _________________
Darbbackwords New Member
Joined: 12 Mar 2010 Posts: 19 Location: Seattle/Whidbey
Posted: Tue Oct 19, 2010 10:14 pm Post subject: |
I am interested in the throttle body, if not the whole motor. Are you willing to sell just the throttle body and for how much? |
