LCA relocation brackets
PostPosted: Mon Jul 19, 2010 11:30 pm    Post subject: LCA relocation brackets Reply with quote
Are there good and bad ones? Or pretty much the same?
The reason why I have been looking at them is because the last few trips to the track I have had some knarly wheel hop doing my burnout. The wierd thing is that when I had the 700R, it NEVER had a wheel hop problem. Is there any other tricks to stopping the wheel hop?
'88 FORMULA
PostPosted: Tue Jul 20, 2010 4:06 am    Post subject: Reply with quote
I think adjusting your pinion angle can?
I guess I have lucked out, both of my cars were lowered and never had wheel hop?? Maybe I just always had crap tires Laughing
PostPosted: Tue Jul 20, 2010 11:42 am    Post subject: Reply with quote
Maybe you have been lucky, or maybe there is something wrong with my car, because it isn't even lowered...
PostPosted: Tue Jul 20, 2010 12:15 pm    Post subject: Reply with quote
I had massively scary wheelhop when my torque arm bolts at the diff came a little bit loose. Check all the rear suspension for loose bolts and worn-out bushings.
A stock height car AFAIK should not have any wheelhop as long as the suspension is in good shape.
PostPosted: Tue Jul 20, 2010 12:22 pm    Post subject: Reply with quote
Shocks good? Control arms at proper level at ride height? Worn out bushings?
PostPosted: Tue Jul 20, 2010 12:40 pm    Post subject: Reply with quote
Derek, your rear shocks have seen better days. You've got the reverse rake going on.
PostPosted: Tue Jul 20, 2010 12:42 pm    Post subject: Reply with quote
Ahem, "California crawl". Very Happy
PostPosted: Tue Jul 20, 2010 12:48 pm    Post subject: Reply with quote
Shocks don't hold the car up :rolleyes:
They will affect wheel hop. The springs oscillate and the worn shocks can't control it. Plus the LCA geometry.
If your car is sagging back, you need springs.
After that, if your control arms point downward from rearend to chassis you need brackets. Get weld on with bolts. I've always bought the Spohn ones and been happy with them. Have them on my 9" now. Use the hole that gets you level or pointing barely up.
A tubular torque arm will help too. I have never had any wheel hop with my car.
PostPosted: Tue Jul 20, 2010 1:58 pm    Post subject: Reply with quote
It sits slightly lower in the back, yes. The shocks squeek over bumps sometimes but there firm, They don't bounce around (I know they don't have anything to do with ride height).
The angle of the LCA isn't level. I guess I'm gonna get under it and tighten everything up since I did swap out the rearend, makes sense that something might have come loose, and I'm sure the hopping doesn't help either. lol
PostPosted: Tue Jul 20, 2010 2:01 pm    Post subject: Reply with quote
So bolt-on ones are no good Paul? That was the main thing I was curious about.
PostPosted: Tue Jul 20, 2010 4:01 pm    Post subject: Reply with quote
I have no experiance with the bolt on ones, they just seem hokey to me. Weld on is that extra piece of mind.
Mangus
1989 Pontiac Trans Am
PostPosted: Wed Jul 28, 2010 8:32 pm    Post subject: Reply with quote
Sorry for the "kinda" jack, but I have a pair of new, unmolested Spohn bolt-ons (which, by the nature of steel, means they're also weld-ons) if anyone wants them. Make me an offer, as long as it's $30.
PostPosted: Fri Aug 06, 2010 8:09 am    Post subject: Reply with quote
Do you have the hardware as well? If so I'll take them.
