rice B-4 Member
Posted: Wed Jan 28, 2004 10:01 am Post subject: My first TBI tune up |
Well I really bonded with my car on Monday, after spending almost 13 hours trying to finish a tune up I finally had to call Dewey to save me from myself and to show me that my rotor wasn?t on all the way. But we got through it and only the MAP sensor tube got broken in the process.
By we broke I mean I broke.
Posted: Wed Jan 28, 2004 10:06 am Post subject: |
MAP not MAF
its a good thing i am somewhat handy with duct-tape  |
TecherB Princess B
Posted: Wed Jan 28, 2004 10:47 am Post subject: |
| you just need some vaccume tube it is better that duct tape. |
Posted: Wed Jan 28, 2004 10:49 am Post subject: |
| its one of the platic hard line tubes. being the MAP sensor, the lenght and ID of the tube will effect readings, so we are going to get him a new one from GM, not just hook some tube up. |
TecherB Princess B
Posted: Wed Jan 28, 2004 11:06 am Post subject: |
| no i ment for your tempotary fix not permnet small vaccume tube holds better than tape |
90RSrocks Member
Joined: 10 Jan 2004 Posts: 421 Location: Klamath Falls, Oregon
Posted: Fri Jan 30, 2004 9:40 pm Post subject: |
Hey if you guys find the part # for that tube, let me know. Mine is in rough shape, and it may be punctured even. The dummy at the dealership I went to couldn't find a # for it.
Thanks guys |
Posted: Mon Feb 02, 2004 4:05 am Post subject: |
| kelly, the v6 is going to be a diffrent part #, the way we found it, was quite a bit of time on the phone, the part number is acutlay listed as a 'engine vacume harness' it includes a couple of lines, and runs about $8 from GM. |
90RSrocks Member
Posted: Mon Feb 02, 2004 3:58 pm Post subject: |
| OK, I'll try a different dealership, see what I can dig up. Thanks John |
