Posted: Thu Jul 08, 2010 4:33 pm Post subject: Recharging AC. |
Well, the AC in my daily driver (2001 camaro) doesn't seem to be blowing cold anymore.
I had it recharged last March (2009). I've been running it a lot recently and did a lot last summer.
Never done the recharges myself.
read up on it a bit here, seems pretty straightforward.
http://www.aa1car.com/library/ac_recharging.htm
anything else that I'll need to be aware of that isn't covered in the link? _________________
Posted: Thu Jul 08, 2010 5:12 pm Post subject: |
To the shizzle in a can. It plugs stuff up and you can't set the pressures or the weights right.
Take it to a pro. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Thu Jul 08, 2010 10:19 pm Post subject: |
I'm going to agree with Paul, I just finished the A/C portion of the auto program over at PCC. With what I know now, I wouldn't even bother with the ol' can and hose.
A shop will be able to hook it to a real machine that can see your high/low pressures, diagnose possible problems and find leaks much easier. Much better than spending 40 bucks on refridgerant and a hose then finding that it still has a problem. _________________
'88 FORMULA |
Posted: Fri Jul 09, 2010 6:40 pm Post subject: |
Thanks for the input guys. Guess I'll let a shop take care of it again. _________________
