Thirdgen Parts for sale
PostPosted: Tue May 18, 2010 5:23 am    Post subject: Thirdgen Parts for sale Reply with quote
I can take pictures if need be and will later. I'll have more to post later too LOL.
$20 - Eibach Rear Springsthink they are pro kit.
$15 - 4 wheel disc Prop Valve.
$offer? - Rear Disc Brake conversion. Good pads. Has backing plates, calipers, rotors, lines, (except the cross axle line), pads, (NO E-BRAKE CABLES)
$20 Radiator. Maybe 2.8? Don't know condition
$20 TPI Dual Snorkal base only w/ K&N filters. Has baffling removed.
$10 T5 Shifter
$20 Manual Pedal Assembly
$20 Clutch Master Cylinder with line and Reservoir/bracket
$15 168 Tooth SFI flexplate
Located in Vancouver. I can transport to Seattle area weekend of Memorial Day.
PostPosted: Tue May 18, 2010 11:16 am    Post subject: Reply with quote
To match his TPI bottom half, I believe I have a top-half for a v8 somewhere. Pay shipping and pp fees on it, thats it.
PostPosted: Tue May 18, 2010 12:57 pm    Post subject: Reply with quote
Paul, I'll take the pedal assembly, shifter, and the Clutch Master Cylinder with line and Reservoir/bracket.
PostPosted: Tue May 18, 2010 1:18 pm    Post subject: Reply with quote
Paul, is the radiator the one you picked up from me for your Chevette project? If so, it came from my 3.1 and was still good when I pulled it. 3.1 uses the same radiator as V8 IIRC, I can check measurements later.
PostPosted: Tue May 18, 2010 2:19 pm    Post subject: Reply with quote
Cool beans Skyler. We'll hook up weekend after this coming.
Al. That rad you gave me went to a core for the one that went on the chevette. Don't know where I ended up with this one. Think it's the same style though.
91camaro_rs
PostPosted: Tue May 18, 2010 9:10 pm    Post subject: Reply with quote
my 3.1 radiator worked for my 5.0
