Crimp-on connectors that insert into the fuse block
PostPosted: Sat May 22, 2010 9:08 pm    Post subject: Crimp-on connectors that insert into the fuse block Reply with quote
Where can I buy stuff like this? I need to add wiring for power seats and want to use the fuse slot that is in the OE fuse block.
PostPosted: Sat May 22, 2010 9:35 pm    Post subject: Reply with quote
Everything that I couldn't find at Grainger locally I've found at www.waytekwire.com
PostPosted: Sat May 22, 2010 9:43 pm    Post subject: Reply with quote
Thanks!
