I think my power hatch pull down is posessed.
PostPosted: Sat May 08, 2010 8:09 pm    Post subject: I think my power hatch pull down is posessed. Reply with quote
I whent to put the t-tops back on my car opened the hatch everything worked fine..... until i whent to close it. When i set it down it latched fine but it didnt pull down. I looked around for a bad ground or bad wire and checked the fuse and didnt see anything wrong, so i left it sit over night. I whent out this afternoon and it had pulled itself down. My car fixed itself Laughing Shrug. So where should i start to look to find out what causes this ? I guess i have a project for my electrics class now Rolling Eyes
kurfbird
PostPosted: Sun May 09, 2010 10:37 am    Post subject: Hatch pull down. Reply with quote
Its sounds like a bad switch at the top near the latch assembly.
They start going bad then work intermidately.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Sun May 09, 2010 10:41 am    Post subject: Re: Hatch pull down. Reply with quote
I'm with stupid
PostPosted: Sun May 09, 2010 11:01 am    Post subject: Reply with quote
For part, pieces, and advise on the pull down motor, contact Lon at
http://www.top-downsolutions.com/
He's very good at diagnosing and selling you the proper repair parts for the hatch motors.
kurfbird
PostPosted: Sun May 09, 2010 11:02 am    Post subject: switch Reply with quote
I believe it is called a hatch sensing switch. It is part of the wiring assembly.
Try to cycle it up an down. Might get it working again.
Pm me your email and I will send you some pics. it might help
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
