fiveoformula Member
Posted: Sun May 16, 2010 7:43 pm Post subject: speedo gear |
| Who sells the aftermarket speedo gears for the T5? I need one calibrated to my 3.73's. I know someone posted the link but I can't find it... |
Posted: Sun May 16, 2010 8:09 pm Post subject: |
That's where I got mine from. Both drive and driven gears. _________________ 92 Camaro
fiveoformula Member
Posted: Sun May 16, 2010 8:21 pm Post subject: |
| Do I need a drive gear too? I was thinking I just need the one on the speed sensor |
Posted: Sun May 16, 2010 8:26 pm Post subject: |
| If your tranny was for a 3.08, it will have a 9 tooth drive gear, the trannies fro the 3.23 and higher rear ends have a 7 tooth drive gear. |
fiveoformula Member
Posted: Sun May 16, 2010 8:29 pm Post subject: |
| Well I got my speed sensor out of a '89 v6 car, that had 3.42 gears, the tranny is out of an '85 Z28 that had 3.23's I believe. |
Posted: Sun May 16, 2010 8:38 pm Post subject: |
| On the tail shaft, the drive gear will either be pink or green. The 7 tooth gear is pink. You should need a 21 tooth driven gear to go with, assuming you have stock height tires. |
fiveoformula Member
Posted: Sun May 16, 2010 8:47 pm Post subject: |
I have the standard 245/50/16's.
So if my drive gear is pink then I need 21 tooth driven gear?
How come they only list a 19 and a 22? |
Posted: Sun May 16, 2010 8:53 pm Post subject: |
| Use the gears for the TH350, they're the same. |
fiveoformula Member
Posted: Sun May 16, 2010 9:00 pm Post subject: |
Oh that explains it...
These work also with the VSS rather than the speedo cable?
Sorry for all the questions, there website seems pretty confusing to me. |
Posted: Sun May 16, 2010 9:07 pm Post subject: |
| Can't answer that one for you. There are also differences in the non VSS bullets for the driven gear, mine had a different length shaft and wouldn't seal in the bullet. Paul found a bullet for me where he worked. |
fiveoformula Member
Posted: Sun May 16, 2010 9:20 pm Post subject: |
Hmm
This may be more of a challenge than I thought.. Thanks for the help though Al, and blue for the link. _________________
'88 FORMULA |
Posted: Mon May 17, 2010 5:58 pm Post subject: |
| Quote: | | '85 Z28 that had 3.23's I believe |
That is correct. Did that gear (I think it was 19 tooth...it was red anyways..) I gave you with the axle not end up not being the right one? _________________
Posted: Mon May 17, 2010 6:52 pm Post subject: |
I hate to be the one way off base here but since you're electronic VSS, won't you be looking for an SGI5 box or something?
edit; missed "be" _________________
fiveoformula Member
Posted: Tue May 18, 2010 9:43 pm Post subject: |
| Quasi-Traction wrote: | | Quote: | | '85 Z28 that had 3.23's I believe |
That is correct. Did that gear (I think it was 19 tooth...it was red anyways..) I gave you with the axle not end up not being the right one? |
Yeah it didn't work cause mine uses the VSS |
fiveoformula Member
Posted: Tue May 18, 2010 9:45 pm Post subject: |
| iansane wrote: | | I hate to the one way off base here but since you're electronic VSS, won't you be looking for an SGI5 box or something? |
Maybe? I really don't know. |
Posted: Tue May 18, 2010 9:55 pm Post subject: |
| Ian, I'm confused. He already has the electronic speedometer, right? Shouldn't it be just a matter of dropping the right gear in the bullet where the pick-up is? Might be different if switching from cable to electronic, although, that Dakota Digital box can make things easier.... |
Posted: Tue May 18, 2010 10:38 pm Post subject: |
| Al Hasse wrote: | | Ian, I'm confused. He already has the electronic speedometer, right? Shouldn't it be just a matter of dropping the right gear in the bullet where the pick-up is? Might be different if switching from cable to electronic, although, that Dakota Digital box can make things easier.... |
I don't know, honestly. Do thirdgen electronic VSSs use gears or a reluctor ring? When I went from 2.73s to 3.23s I also swapped in the t56 which used the reluctor ring setup. The Dakota Digital box made up for the change in output (4kppm) and the ratio change.
I'm thinking if the electronic thirdgen VSS uses gears they you don't need the sgi5 because you CAN swap gears. However, if it uses the reluctor ring setup like 4thgens/t56s then you can't swap gears so you HAVE to use the sgi5. Right? |
Posted: Tue May 18, 2010 10:57 pm Post subject: |
The T-5s in Firebirds and later Camaros used a gear with a pickup on it rather than the ring, IIRC. So you would be correct, yes.  |
fiveoformula Member
Posted: Wed May 19, 2010 9:52 pm Post subject: |
| So now im confused, can't I just swap that gear? It came with the cable bullet, I swaped it out for the VSS out of a later third gen just fine. |
