GREG DAVIDSON Member
Posted: Sat May 08, 2010 8:09 pm Post subject: I think my power hatch pull down is posessed. |
I whent to put the t-tops back on my car opened the hatch everything worked fine..... until i whent to close it. When i set it down it latched fine but it didnt pull down. I looked around for a bad ground or bad wire and checked the fuse and didnt see anything wrong, so i left it sit over night. I whent out this afternoon and it had pulled itself down. My car fixed itself . So where should i start to look to find out what causes this ? I guess i have a project for my electrics class now  _________________
kurfbird Member
Posted: Sun May 09, 2010 10:37 am Post subject: Hatch pull down. |
Its sounds like a bad switch at the top near the latch assembly.
They start going bad then work intermidately. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Sun May 09, 2010 10:41 am Post subject: Re: Hatch pull down. |
| kurfbird wrote: | Its sounds like a bad switch at the top near the latch assembly.
They start going bad then work intermidately. |
alloy T56 Elitist
Posted: Sun May 09, 2010 11:01 am Post subject: |
For part, pieces, and advise on the pull down motor, contact Lon at
http://www.top-downsolutions.com/
He's very good at diagnosing and selling you the proper repair parts for the hatch motors. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
kurfbird Member
Posted: Sun May 09, 2010 11:02 am Post subject: switch |
I believe it is called a hatch sensing switch. It is part of the wiring assembly.
Try to cycle it up an down. Might get it working again.
Pm me your email and I will send you some pics. it might help _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
