Spacers/wheel adapters?
PostPosted: Wed Jan 27, 2010 9:13 pm    Post subject: Spacers/wheel adapters? Reply with quote
Any good or bad companies making wheel spacers? Anything to avoid?
Looking for something along these lines:
http://cgi.ebay.com/ebaymotors/WHEEL-SPACERS-ADAPTERS-FORD-BRONCO-F150-4pcs-5x5-5_W0QQitemZ370207890626QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item56321c1cc2#ht_1389wt_965
Don't need to adapt to any different wheels, I just need to push the rims out an inch or two.
PostPosted: Wed Jan 27, 2010 11:02 pm    Post subject: Reply with quote
Make sure if you need hub centric that they are!
I bought some for the Mazda. They wanted make/model/year and what I was going to convert to.
Mazda has hubcentric wheels. Spacers came... they built them lug centric. Shook like a dog shittin' peach pits. I had to machine spacers to center the adapters AND the new wheel. Wasn't fun.
PostPosted: Wed Jan 27, 2010 11:09 pm    Post subject: Reply with quote
Come to think of it, that truck is hub centric. Surprised
Thanks for the heads up, Paul.
Leejo2005
PostPosted: Thu Jan 28, 2010 8:35 am    Post subject: Reply with quote
Classic.
PostPosted: Sat Jan 30, 2010 7:23 pm    Post subject: Reply with quote
I saw a bunch of cheap wheel spacers online and got scared. Ended up spending the extra doh and getting the H&R's. Real nice though. SOLID and hug centric. The cheapies looked like they were cast and were missing some metal. Plus this way I can go to the place I got them instead of dealing with an online company.
an inch or two
Lol, huge difference there man.
PostPosted: Sun Jan 31, 2010 2:44 pm    Post subject: Reply with quote
I bought mine through an eBay seller. They did not, however, have the correct center bore. I had to dremel them out to get them to fit, tightly at that. I'll update later with which seller it was.
PostPosted: Sun Jan 31, 2010 5:39 pm    Post subject: Reply with quote
Bought mine from ebay years ago. They were cheap. Something like $75 for all four? Fit fine and have taken some pretty hefty abuse. Very Happy
PostPosted: Sun Jan 31, 2010 9:09 pm    Post subject: Reply with quote
Ian, I was gonna go with VBP (Vette Brakes and Products) spacers for my Z06 wheels as thats what I know a bunch of guys on TGO are using. Do you know who made your Ebay ones?
PostPosted: Sun Jan 31, 2010 10:03 pm    Post subject: Reply with quote
I was going to say I had no idea who I got them from but I checked paypals history and voila! I bought them Jun 2nd, 2004 from a guy named Dwight Long. Seller ID on eBay "completevalue"
They went up in price a bit. I payed $78 for all four.
Like this;
http://cgi.ebay.com/ebaymotors/Chevy-S10-Corvette-Camaro-Wheels-2-Wheel-Spacers_W0QQitemZ270502435528QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3efb339ac8
PostPosted: Mon Feb 01, 2010 12:41 am    Post subject: Reply with quote
I bought mine here.
PostPosted: Mon Feb 01, 2010 8:32 am    Post subject: Reply with quote
Hmm... those are the same ones I ended up buying... I'm outta here
Guess I'll really have to remember to retorque before I hit the freeway.
PostPosted: Wed Apr 07, 2010 3:21 pm    Post subject: Reply with quote
Like this;
I thought the centerbore for 3rd gens is 70.5mm? Those say they're 78.3. Can anyone verify which is correct?
PostPosted: Wed Apr 07, 2010 4:40 pm    Post subject: Reply with quote
Talking the Hub size? It's pretty standard for 4 3/4 on 5 patterns. Vettes are the same.
PostPosted: Fri Apr 09, 2010 2:11 pm    Post subject: Reply with quote
Well I just bought the same ones Ian did. I hope these work out a little better than my last set.
PostPosted: Fri Apr 09, 2010 2:12 pm    Post subject: Reply with quote
Re-torque them per spec. Then re-torque them again.
They don't "fail" by having the lugnuts unscrew. That's your beans! Wink
PostPosted: Fri Apr 09, 2010 4:01 pm    Post subject: Reply with quote
Confused I never said mine "failed," the center bore on my last set was too small to even put the adapter on. I had to expand the bore in order to even mount them.
PostPosted: Fri Apr 09, 2010 4:22 pm    Post subject: Reply with quote
Careful, this time your whole car will end up in the bushes. Very Happy
PostPosted: Fri Apr 09, 2010 7:20 pm    Post subject: Reply with quote
Hey! zip it Wedgie time! ::knock on wood:: Wink
