quick spark plug wire question
91camaro_rs
PostPosted: Mon Mar 22, 2010 10:16 pm    Post subject: quick spark plug wire question Reply with quote
ok so im putting headers on my 305, should i get 90* spark plug wires or straight ones?
PostPosted: Mon Mar 22, 2010 10:17 pm    Post subject: Reply with quote
Full set of 90's.
91camaro_rs
PostPosted: Mon Mar 22, 2010 10:19 pm    Post subject: Reply with quote
thanks!!
im buying a whole ton of stuff from summit right now, just wanted to make sure i get the right stuff before i buy it.
PostPosted: Tue Mar 23, 2010 2:16 pm    Post subject: Reply with quote
Might consider buying some kind of wire holders/separators. Helps keep things organized and keeps plug wires off header tubes.
PostPosted: Tue Mar 23, 2010 2:27 pm    Post subject: Reply with quote
You've got perimeter bolt valve covers on that 305, so you have a million choices for looms and holders. I had to build some for my centerbolt setup out of Taylor wire looms, but I really liked what I ended up with.
PostPosted: Tue Mar 23, 2010 2:38 pm    Post subject: Reply with quote
I got some "cut-to-length" wires and routed them under the headers, looks clean. Might have to swap sides with them though, or do new ones again. My passenger side wires have quite a bit more slack than the driver side wires do.
PostPosted: Tue Mar 23, 2010 3:01 pm    Post subject: Reply with quote
Careful running them under the headers. The '85 Iroc had one side come that way from the factory and the looms would get hot and break causing the wires to swing into the exhaust.
Zip ties work well too. Zip tie 1-3 and 5-7 etc together between the tubes. Then follow up towards the dizzy.
PostPosted: Tue Mar 23, 2010 9:35 pm    Post subject: Reply with quote
Zip ties FTW. That's how I did them. One ziptie to grab two wires together and a ziptie between them to keep them separated.
PostPosted: Wed Mar 24, 2010 6:21 am    Post subject: Reply with quote
Zip ties are the most cost-effective way of keeping plug wires organized. Of course, then you have to cut them off and replace them every time you get new wires. Could get expensive after a while. Laughing
PostPosted: Wed Mar 24, 2010 9:10 pm    Post subject: Reply with quote
Do the 90's help on the log manifolds that go above the plugs? My old roomie has that setup and is going through wires. I had shorties on my LT1 and used the MSD custom length with 90* boots (with opti spark).
PostPosted: Thu Mar 25, 2010 11:52 am    Post subject: Reply with quote
IIRC some were 90/90's and some were 90/straight on my old 85 with log manifolds.
Problem could be the wires themselves, aftermarket (MSD, Taylor...etc) have better insulation than the part store OEM replacements.
PostPosted: Thu Mar 25, 2010 6:29 pm    Post subject: Reply with quote
That's how Chevy did most of them. It seemed to vary based on what manifold you had though.
